I tried flashing an image - dau-min-image-imx6dldau.encryptedsdcard.bz2 onto my SD card [ 16 GB ]. During Validation - it says flash failed at the end.
Trial 1: Used a different SD Card - Same issue.
Trial 2: Ran Balena Etcher as Administrator - same error.
Trial 3: Used a different USB port [ Using a USB Card Reader - New unit, attached SD Card ], Ran Balena as admin - Still the issue persists.
Here is the console output:
Version = 1.5.122, Type = nsis
Mon Sep 27 2021 11:40:21 GMT+0530 (India Standard Time) Application start ({“packageType”:“nsis”,“version”:“1.5.122”,“sample”:0.1,“applicationSessionUuid”:“769b57df-2126-401e-b7ff-ac7a5f6cbcb9”,“flashingWorkflowUuid”:“bfbcfc5c-9c9c-43bb-b891-db19f3aa5097”})
Mon Sep 27 2021 11:40:23 GMT+0530 (India Standard Time) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“769b57df-2126-401e-b7ff-ac7a5f6cbcb9”,“flashingWorkflowUuid”:“bfbcfc5c-9c9c-43bb-b891-db19f3aa5097”})
Mon Sep 27 2021 11:40:28 GMT+0530 (India Standard Time) Select image ({“image”:{“isCompressed”:true,“name”:“dau-min-image-imx6dldau.encryptedsdcard”,“size”:7511998464,“compressedSize”:576607774,“isSizeEstimated”:true,“hasMBR”:true,“partitions”:[{“offset”:4194304,“size”:33554432,“type”:12,“index”:1},{“offset”:37748736,“size”:7474249728,“type”:131,“index”:2}],“extension”:“bz2”,“path”:“C:\Users\invirm\Downloads\dau-min-image-imx6dldau.encryptedsdcard.bz2”,“logo”:false,“blockMap”:false},“sample”:0.1,“applicationSessionUuid”:“769b57df-2126-401e-b7ff-ac7a5f6cbcb9”,“flashingWorkflowUuid”:“bfbcfc5c-9c9c-43bb-b891-db19f3aa5097”})
Mon Sep 27 2021 11:40:32 GMT+0530 (India Standard Time) Flash ({“image”:{“size”:7511998464,“compressedSize”:576607774,“hasMBR”:true,“path”:“C:\Users\invirm\Downloads\dau-min-image-imx6dldau.encryptedsdcard.bz2”,“partitions”:[{“offset”:4194304,“size”:33554432,“type”:12,“index”:1},{“offset”:37748736,“size”:7474249728,“type”:131,“index”:2}],“isCompressed”:true,“name”:“dau-min-image-imx6dldau.encryptedsdcard”,“isSizeEstimated”:true,“extension”:“bz2”},“drives”:[{“size”:15931539456,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive2”,“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive2”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“MXT-USB Storage Device USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“92bda403-8669-46f2-a8a0-6b9375381cea”,“status”:“started”,“flashInstanceUuid”:“92bda403-8669-46f2-a8a0-6b9375381cea”,“sample”:0.1,“applicationSessionUuid”:“769b57df-2126-401e-b7ff-ac7a5f6cbcb9”,“flashingWorkflowUuid”:“bfbcfc5c-9c9c-43bb-b891-db19f3aa5097”})
Elevating command: C:\Users\invirm\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\invirm\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js
Successfully connected to IPC server: etcher-server-14540, socket root C:\Users\invirm\AppData\Local\Temp
Image: C:\Users\invirm\Downloads\dau-min-image-imx6dldau.encryptedsdcard.bz2
Devices: \.\PhysicalDrive2
gui.js:51120 Auto blockmapping: true
gui.js:51120 Decompress first: true
gui.js:51120 Mon Sep 27 2021 11:40:33 GMT+0530 (India Standard Time) SafeWebview loaded ({“event”:{“id”:1,“url”:“https://www.balena.io/etcher/featured 200 OK”,“statusCode”:200,“responseHeaders”:{“Age”:[“206”],“CF-Cache-Status”:[“DYNAMIC”],“CF-RAY”:[“695291ce7ad74c7d-SIN”],“Cache-Control”:[“max-age=600”],“Connection”:[“keep-alive”],“Content-Encoding”:[“br”],“Content-Type”:[“text/html; charset=utf-8”],“Date”:[“Mon, 27 Sep 2021 06:10:33 GMT”],“Expect-CT”:[“max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct\”“],“Expires”:[“Fri, 24 Sep 2021 22:24:50 GMT”],“Last-Modified”:[“Fri, 24 Sep 2021 22:13:06 GMT”],“NEL”:[”{"success_fraction":0,"report_to":"cf-nel","max_age":604800}“],“Report-To”:[”{"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=yuwivvxA4q1a0AVYDqzOjoCc%2F1XXhL3aoIR0lV8ig5BzZI%2FfE5Jd54S6hwlRkrdT4w4IY7quxPk%2F50Z6hA4P5Fw8qE0DBb%2BNLmUPssRFrePGacLGBZ2xDJz9atqLuELh6LpC"}],"group":"cf-nel","max_age":604800}“],“Transfer-Encoding”:[“chunked”],“Vary”:[“Accept-Encoding”],“Via”:[“1.1 varnish”,“ICAP/1.0 cn1735373871-9-vnsg13951.ibosscloud.com (IBOSS/0.4.4 iboss ICAP service )”],“X-Cache”:[“HIT”,“MISS from cn1735373871-9-vnsg13951.ibosscloud.com”],“access-control-allow-origin”:[”*“],“alt-svc”:[“h3=":443"; ma=86400, h3-29=":443"; ma=86400, h3-28=":443"; ma=86400, h3-27=":443"; ma=86400”],“x-cache-hits”:[“1”],“x-fastly-request-id”:[“42482b6f3b710c0a49d3d259726166c32013dd27”],“x-github-request-id”:[“1C74:582F:1051C59:1710050:614E4DDA”],“x-origin-cache”:[“HIT”],“x-proxy-cache”:[“MISS”],“x-served-by”:[“cache-qpg1278-QPG”],“x-timer”:[“S1632723033.386036,VS0,VE1”]},“referrer”:”",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“769b57df-2126-401e-b7ff-ac7a5f6cbcb9”,“flashingWorkflowUuid”:“bfbcfc5c-9c9c-43bb-b891-db19f3aa5097”})
gui.js:38464 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:38464 Flashing 1 device, 0% at 3.20 MB/s (total 3.20 MB/s) eta in 2334s with 0 failed devices
gui.js:38464 Flashing 1 device, 0% at 5.10 MB/s (total 5.10 MB/s) eta in 1462s with 0 failed devices
gui.js:51120 {“message”:“connect ETIMEDOUT 167.99.78.230:443”,“stack”:“Error: connect ETIMEDOUT 167.99.78.230:443\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1146:16)”,“config”:{“url”:“https://balena.io/etcher/static/config.json",“method”:“get”,“headers”:{“Accept”:"application/json, text/plain, /”,“User-Agent”:“axios/1.5.122”},“transformRequest”:[null],“transformResponse”:[null],“timeout”:0,“responseType”:“json”,“xsrfCookieName”:“XSRF-TOKEN”,“xsrfHeaderName”:“X-XSRF-TOKEN”,“maxContentLength”:-1,“maxBodyLength”:-1},“code”:“ETIMEDOUT”}
console. @ gui.js:51120gui.js:51120 Mon Sep 27 2021 11:58:34 GMT+0530 (India Standard Time) Validation error ({“image”:{“size”:7511998464,“compressedSize”:576607774,“hasMBR”:true,“path”:“C:\Users\invirm\Downloads\dau-min-image-imx6dldau.encryptedsdcard.bz2”,“partitions”:[{“offset”:4194304,“size”:33554432,“type”:12,“index”:1},{“offset”:37748736,“size”:7474249728,“type”:131,“index”:2}],“isCompressed”:true,“name”:“dau-min-image-imx6dldau.encryptedsdcard”,“isSizeEstimated”:true,“extension”:“bz2”},“drives”:[{“size”:15931539456,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive2”,“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive2”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“MXT-USB Storage Device USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“92bda403-8669-46f2-a8a0-6b9375381cea”,“flashInstanceUuid”:“92bda403-8669-46f2-a8a0-6b9375381cea”,“sample”:0.1,“applicationSessionUuid”:“769b57df-2126-401e-b7ff-ac7a5f6cbcb9”,“flashingWorkflowUuid”:“bfbcfc5c-9c9c-43bb-b891-db19f3aa5097”})
gui.js:38464 Verifying 1 device, 100% at 18.70 MB/s (total 18.70 MB/s) eta in 0s with 0 failed devices
gui.js:51120 Finish: 7516192768
gui.js:51120 Terminating IPC server
gui.js:51120 Flash results {results: {…}, cancelled: false, skip: false}
gui.js:51120 Mon Sep 27 2021 11:58:37 GMT+0530 (India Standard Time) Done ({“image”:{“size”:7511998464,“compressedSize”:576607774,“hasMBR”:true,“path”:“C:\Users\invirm\Downloads\dau-min-image-imx6dldau.encryptedsdcard.bz2”,“partitions”:[{“offset”:4194304,“size”:33554432,“type”:12,“index”:1},{“offset”:37748736,“size”:7474249728,“type”:131,“index”:2}],“isCompressed”:true,“name”:“dau-min-image-imx6dldau.encryptedsdcard”,“isSizeEstimated”:true,“extension”:“bz2”},“drives”:[{“size”:15931539456,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive2”,“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive2”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“MXT-USB Storage Device USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“92bda403-8669-46f2-a8a0-6b9375381cea”,“status”:“finished”,“flashInstanceUuid”:“92bda403-8669-46f2-a8a0-6b9375381cea”,“errors”:[{“name”:“Error”,“description”:“MXT-USB Storage Device USB Device”,“code”:“EVALIDATION”,“device”:“\\.\PhysicalDrive2”}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:7516192768,“sourceMetadata”:{“isCompressed”:true,“name”:“dau-min-image-imx6dldau.encryptedsdcard”,“size”:7516192768,“compressedSize”:576607774,“isSizeEstimated”:false},“sample”:0.1,“applicationSessionUuid”:“769b57df-2126-401e-b7ff-ac7a5f6cbcb9”,“flashingWorkflowUuid”:“bfbcfc5c-9c9c-43bb-b891-db19f3aa5097”})
I could not make out much sense out of the output log to determine the cause of error.
Can you please help me identify as in where the issue lies? [ Have also tried with Rufus but wasn’t possible. ]
Nathan
