Attached are a picture of my application build, a copy of the docker-compose file, and a readout of the balenacloud terminal. I have successfully pushed the image but I am still having trouble accessing VNC through both the ip:9090 and a VNC viewer.
version: "2"
services:
srly-ose-server:
image: screenly/srly-ose-server
build:
context: .
dockerfile: docker/Dockerfile.server
environment:
- HOME=/data
- LISTEN=0.0.0.0
- CELERY_BROKER_URL=redis://redis:6379/0
- CELERY_RESULT_BACKEND=redis://redis:6379/0
devices:
- "/dev/vchiq:/dev/vchiq"
restart: always
volumes:
- resin-data:/data
labels:
srly-ose-viewer:
image: screenly/srly-ose-viewer
build:
context: .
dockerfile: docker/Dockerfile.viewer
depends_on:
- srly-ose-server
environment:
- HOME=/data
- PORT=80
- NOREFRESH=1
- LISTEN=srly-ose-nginx
privileged: true
restart: always
volumes:
- resin-data:/data
srly-ose-websocket:
image: screenly/srly-ose-websocket
build:
context: .
dockerfile: docker/Dockerfile.websocket
depends_on:
- srly-ose-server
environment:
- HOME=/data
- LISTEN=0.0.0.0
restart: always
volumes:
- resin-data:/data
srly-ose-celery:
image: screenly/srly-ose-celery
build:
context: .
dockerfile: docker/Dockerfile.celery
depends_on:
- srly-ose-server
- redis
environment:
- HOME=/data
devices:
restart: always
volumes:
- resin-data:/data
redis:
image: screenly/srly-ose-redis
build:
context: .
dockerfile: docker/Dockerfile.redis
ports:
- 127.0.0.1:6379:6379
restart: always
volumes:
- redis-data:/var/lib/redis
srly-ose-nginx:
image: screenly/srly-ose-nginx
build:
context: .
dockerfile: docker/Dockerfile.nginx
ports:
- 8080:80
environment:
- HOME=/data
depends_on:
- srly-ose-server
- srly-ose-websocket
restart: always
volumes:
- resin-data:/data:ro
xserver:
image: balenablocks/xserver
restart: always
privileged: true
volumes:
- 'xserver:/tmp/.X11-unix'
xserver-web-vnc:
build: .
restart: always
network_mode: host
privileged: true
volumes:
environment:
WEB_PORT: 80
DISABLE_PASSWORDS: true
volumes:
resin-data:
redis-data:
data:
xserver:
Here is a terminal readout of xserver-web-vnc
Restarting service 'xserver-web-vnc sha256:d28742d9fdb47519b2855dc3e3a3829f0ab06517a244d802f98d8b689a0978f7'
xserver-web-vnc Disabling password protection
xserver-web-vnc Enabling view-only mode
xserver-web-vnc
xserver-web-vnc #
xserver-web-vnc # Starting x11vnc
xserver-web-vnc #
xserver-web-vnc 21/08/2021 02:46:24 passing arg to libvncserver: -listen
xserver-web-vnc 21/08/2021 02:46:24 passing arg to libvncserver: localhost
xserver-web-vnc ###############################################################
xserver-web-vnc #@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@#
xserver-web-vnc #@ @#
xserver-web-vnc #@ ** WARNING ** WARNING ** WARNING ** WARNING ** @#
xserver-web-vnc #@ YOU ARE RUNNING X11VNC WITHOUT A PASSWORD!! @#
xserver-web-vnc #@ This means anyone with network access to this computer @#
xserver-web-vnc #@ may be able to view and control your desktop. @#
xserver-web-vnc #@ >>> If you did not mean to do this Press CTRL-C now!! <<< @#
xserver-web-vnc #@ You can create an x11vnc password file by running: @#
xserver-web-vnc #@ x11vnc -storepasswd password /path/to/passfile @#
xserver-web-vnc #@ or x11vnc -storepasswd /path/to/passfile @#
xserver-web-vnc #@ or x11vnc -storepasswd @#
xserver-web-vnc #@ (the last one will use ~/.vnc/passwd) @#
xserver-web-vnc #@ and then starting x11vnc via: @#
xserver-web-vnc #@ x11vnc -rfbauth /path/to/passfile @#
xserver-web-vnc #@ an existing ~/.vnc/passwd file from another VNC @#
xserver-web-vnc #@ application will work fine too. @#
xserver-web-vnc #@ You can also use the -passwdfile or -passwd options. @#
xserver-web-vnc #@ (note -passwd is unsafe if local users are not trusted) @#
xserver-web-vnc #@ Make sure any -rfbauth and -passwdfile password files @#
xserver-web-vnc #@ cannot be read by untrusted users. @#
xserver-web-vnc #@ Use x11vnc -usepw to automatically use your @#
xserver-web-vnc #@ ~/.vnc/passwd or ~/.vnc/passwdfile password files. @#
xserver-web-vnc #@ (and prompt you to create ~/.vnc/passwd if neither @#
xserver-web-vnc #@ file exists.) Under -usepw, x11vnc will exit if it @#
xserver-web-vnc #@ cannot find a password to use. @#
xserver-web-vnc #@ Even with a password, the subsequent VNC traffic is @#
xserver-web-vnc #@ sent in the clear. Consider tunnelling via ssh(1): @#
xserver-web-vnc #@ http://www.karlrunge.com/x11vnc/#tunnelling @#
xserver-web-vnc #@ Or using the x11vnc SSL options: -ssl and -stunnel @#
xserver-web-vnc #@ Please Read the documentation for more info about @#
xserver-web-vnc #@ passwords, security, and encryption. @#
xserver-web-vnc #@ http://www.karlrunge.com/x11vnc/faq.html#faq-passwd @#
xserver-web-vnc #@ To disable this warning use the -nopw option, or put @#
xserver-web-vnc #@ 'nopw' on a line in your ~/.x11vncrc file. @#
xserver-web-vnc 21/08/2021 02:46:25 x11vnc version: 0.9.16 lastmod: 2019-01-05 pid: 10
xserver-web-vnc 21/08/2021 02:46:26 Using X display :0
xserver-web-vnc 21/08/2021 02:46:26 rootwin: 0x50f reswin: 0x600001 dpy: 0x9a4d6f70
xserver-web-vnc 21/08/2021 02:46:26 ------------------ USEFUL INFORMATION ------------------
xserver-web-vnc 21/08/2021 02:46:26 X DAMAGE available on display, using it for polling hints.
xserver-web-vnc 21/08/2021 02:46:26 To disable this behavior use: '-noxdamage'
xserver-web-vnc 21/08/2021 02:46:26 Most compositing window managers like 'compiz' or 'beryl'
xserver-web-vnc 21/08/2021 02:46:26 cause X DAMAGE to fail, and so you may not see any screen
xserver-web-vnc 21/08/2021 02:46:26 updates via VNC. Either disable 'compiz' (recommended) or
xserver-web-vnc 21/08/2021 02:46:26 supply the x11vnc '-noxdamage' command line option.
xserver-web-vnc 21/08/2021 02:46:26 Wireframing: -wireframe mode is in effect for window moves.
xserver-web-vnc 21/08/2021 02:46:26 If this yields undesired behavior (poor response, painting
xserver-web-vnc 21/08/2021 02:46:26 errors, etc) it may be disabled:
xserver-web-vnc 21/08/2021 02:46:26 - use '-nowf' to disable wireframing completely.
xserver-web-vnc 21/08/2021 02:46:26 - use '-nowcr' to disable the Copy Rectangle after the
xserver-web-vnc 21/08/2021 02:46:26 moved window is released in the new position.
xserver-web-vnc 21/08/2021 02:46:26 Also see the -help entry for tuning parameters.
xserver-web-vnc 21/08/2021 02:46:26 You can press 3 Alt_L's (Left "Alt" key) in a row to
xserver-web-vnc 21/08/2021 02:46:26 repaint the screen, also see the -fixscreen option for
xserver-web-vnc 21/08/2021 02:46:26 periodic repaints.
xserver-web-vnc 21/08/2021 02:46:26 XFIXES available on display, resetting cursor mode
xserver-web-vnc 21/08/2021 02:46:26 to: '-cursor most'.
xserver-web-vnc 21/08/2021 02:46:26 to disable this behavior use: '-cursor arrow'
xserver-web-vnc 21/08/2021 02:46:26 or '-noxfixes'.
xserver-web-vnc 21/08/2021 02:46:26 using XFIXES for cursor drawing.
xserver-web-vnc 21/08/2021 02:46:26 GrabServer control via XTEST.
xserver-web-vnc 21/08/2021 02:46:26 Scroll Detection: -scrollcopyrect mode is in effect to
xserver-web-vnc 21/08/2021 02:46:26 use RECORD extension to try to detect scrolling windows
xserver-web-vnc 21/08/2021 02:46:26 (induced by either user keystroke or mouse input).
xserver-web-vnc 21/08/2021 02:46:26 errors, etc) it may be disabled via: '-noscr'
xserver-web-vnc 21/08/2021 02:46:26 XKEYBOARD: number of keysyms per keycode 7 is greater
xserver-web-vnc 21/08/2021 02:46:26 than 4 and 51 keysyms are mapped above 4.
xserver-web-vnc 21/08/2021 02:46:26 Automatically switching to -xkb mode.
xserver-web-vnc 21/08/2021 02:46:26 If this makes the key mapping worse you can
xserver-web-vnc 21/08/2021 02:46:26 disable it with the "-noxkb" option.
xserver-web-vnc 21/08/2021 02:46:26 Also, remember "-remap DEAD" for accenting characters.
xserver-web-vnc 21/08/2021 02:46:26 X FBPM extension not supported.
xserver-web-vnc 21/08/2021 02:46:26 X display is capable of DPMS.
xserver-web-vnc 21/08/2021 02:46:26 --------------------------------------------------------
xserver-web-vnc 21/08/2021 02:46:26 Default visual ID: 0x21
xserver-web-vnc 21/08/2021 02:46:26 Read initial data from X display into framebuffer.
xserver-web-vnc 21/08/2021 02:46:26 initialize_screen: fb_depth/fb_bpp/fb_Bpl 24/32/7680
xserver-web-vnc 21/08/2021 02:46:26 X display :0 is 32bpp depth=24 true color
xserver-web-vnc 21/08/2021 02:46:26 Autoprobing TCP port
xserver-web-vnc 21/08/2021 02:46:26 Autoprobing selected TCP port 5900
xserver-web-vnc 21/08/2021 02:46:26 Autoprobing TCP6 port
xserver-web-vnc 21/08/2021 02:46:26 Autoprobing selected TCP6 port 5900
xserver-web-vnc 21/08/2021 02:46:26 listen6: bind: Address already in use
xserver-web-vnc 21/08/2021 02:46:26 Not listening on IPv6 interface.
xserver-web-vnc 21/08/2021 02:46:26 Xinerama is present and active (e.g. multi-head).
xserver-web-vnc 21/08/2021 02:46:26 Xinerama: number of sub-screens: 1
xserver-web-vnc 21/08/2021 02:46:26 Xinerama: no blackouts needed (only one sub-screen)
xserver-web-vnc
xserver-web-vnc X11 MIT Shared Memory Attach failed:
xserver-web-vnc Is your DISPLAY=:0 on a remote machine?
xserver-web-vnc Suggestion, use: x11vnc -display :0 ... for local display :0
xserver-web-vnc
xserver-web-vnc caught X11 error:
xserver-web-vnc 21/08/2021 02:46:26 deleted 60 tile_row polling images.
xserver-web-vnc X Error of failed request: BadAccess (attempt to access private resource denied)
xserver-web-vnc Major opcode of failed request: 130 (MIT-SHM)
xserver-web-vnc Minor opcode of failed request: 1 (X_ShmAttach)
xserver-web-vnc Serial number of failed request: 56
xserver-web-vnc Current serial number in output stream: 118
xserver-web-vnc /entry.sh: 37: -no6: not found
xserver-web-vnc
xserver-web-vnc #
xserver-web-vnc # Starting novnc
xserver-web-vnc #
xserver-web-vnc
xserver-web-vnc WebSocket server settings:
xserver-web-vnc - Listen on :80
xserver-web-vnc - Web server. Web root: /usr/share/novnc
xserver-web-vnc - No SSL/TLS support (no cert file)
xserver-web-vnc Traceback (most recent call last):
xserver-web-vnc File "/usr/bin/websockify", line 33, in <module>
xserver-web-vnc sys.exit(load_entry_point('websockify==0.9.0', 'console_scripts', 'websockify')())
xserver-web-vnc File "/usr/lib/python3/dist-packages/websockify/websocketproxy.py", line 726, in websockify_init
xserver-web-vnc server.start_server()
xserver-web-vnc File "/usr/lib/python3/dist-packages/websockify/websockifyserver.py", line 737, in start_server
xserver-web-vnc lsock = self.socket(self.listen_host, self.listen_port, False,
xserver-web-vnc File "/usr/lib/python3/dist-packages/websockify/websockifyserver.py", line 488, in socket
xserver-web-vnc sock.bind(addrs[0][4])
xserver-web-vnc OSError: [Errno 98] Address already in use
Also, when a url address video is playing, such as youtube, the sound plays, but the video no longer appears. In its place is a black mouse cursor. This tells me that the vnc program and screenly appear to be fighting each other.
