RPI 4 - Not booting OS
I’m provisioning some new rpi4 (4GB) devices to my openbalena env. but have a problem with the os not booting. I only get black screen on de hdmi (not the balena logo). On the ethernet both lights or on, and have no led flashes. Is it possible to get boot message on the screen ?
i tested with 2.58.6 & 2.80.5 version.
rpi os boots without problem.
Hey @RafS welcome to the balena Forums! That’s really odd what you describe! You should be able to see something on the screen. Are you using keyboard on the Raspberry Pi?
Could you please try with a blank application (no code pushed) on your openBalena environment? What do you see?
If that doesn’t work, maybe it’s a good idea if you could try to download an un-managed image directly from our OS website and try again with keyboard and hdmi?
Let us know what do you see!
meanwhile i found that i can boot the device with version 2.73 and higher also registration in openbalena works now.
Regards
Raf
Good to know! thanks for the update!
