I´m a first time user of Balena OS and Balena Cloud. I´m having problems with connection (4 short flashes) through ethernet. So I tried to open all required ports, multiple cables, redownload OS, but that didn´t work and I don´t see RPI on my network.
Hi @Orsen,
Welcome to the forums! You shouldn’t have to open ports because all device network traffic passes through the built-in balena VPN using port 443. Did you set up “ethernet only” during the image download or did you also add wifi credentials? Adding wifi would be a good way to check if the RPi’s ethernet port has an issue.
John
Thank you for the response,
so I tried WI-FI and it worked! But I don´t know how to make it work with ethernet. I even tried the same cable as I’m using right now.
Hey, that’s certainly strange! Let’s try to get to the bottom of these issues. Firstly if possible I’d like for you to install a dev version of balenaOS on your device. This will cause it to “broadcast” it’s hostname across the LAN. So to detect that “broadcast”, I would then ask you to install balena-cli and run balena scan using sudo on OSX or linux and an administrator terminal on windows.
What I’m looking for here is at least 1 entry from the scan command, which shows us the device is in fact connected to the LAN. If this shows up, we then want to ssh in using balena ssh <ip address> where <ip address> is the address found in balena scan. From there, run journalctl -f -u resin-supervisor -n 10000 and paste the results here please.
If the device is not connected to the LAN, something seriously more weird is going on, so we can debug that then if necessary
I downloaded a new image of ethernet Balena OS, flashed with Etcher and I still didn´t see it through balena cli even when I switched cables.
P.S. other distros work with ethernet.
Did you definitely download a dev version of the OS?
balena-cloud-RPI02-raspberrypi4-64-2.51.1+rev1-dev-v11.4.10.img
Hey,
Can you please connect the Raspberry pi though wifi and ethernet at the same time? In essence, repeat the steps that you followed to connect the device via wifi and then simply connect the ethernet cable. After you do this, can you find the device using balena scan?
thank you for reply,
https://pastebin.com/xF31cawi
Thanks for the output. Can you please verify that the device is connected to the ethernet (as also the wifi) and run the command ifconfig inside the device, afterwards please copy the output here aswell.
balena0 Link encap:Ethernet HWaddr 02:42:89:50:0D:EA
inet addr:10.114.101.1 Bcast:10.114.101.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
br-37ee75c24d37 Link encap:Ethernet HWaddr 02:42:70:81:4B:5A
inet addr:172.18.0.1 Bcast:172.18.255.255 Mask:255.255.0.0
eth0 Link encap:Ethernet HWaddr DC:A6:32:47:FC:F0
inet6 addr: fe80::f867:8c97:363c:9d53/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2163 errors:0 dropped:0 overruns:0 frame:0
TX packets:104 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:336414 (328.5 KiB) TX bytes:27879 (27.2 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1226 errors:0 dropped:0 overruns:0 frame:0
TX packets:1226 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:106592 (104.0 KiB) TX bytes:106592 (104.0 KiB)
resin-dns Link encap:Ethernet HWaddr AA:90:3B:0B:55:44
inet addr:10.114.102.1 Bcast:0.0.0.0 Mask:255.255.255.0
inet6 addr: fe80::a890:3bff:fe0b:5544/64 Scope:Link
TX packets:68 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:12097 (11.8 KiB)
resin-vpn Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.240.53.210 P-t-P:52.4.252.97 Mask:255.255.255.255
inet6 addr: fe80::a729:575a:4cc4:55f6/64 Scope:Link
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:480 (480.0 B)
supervisor0 Link encap:Ethernet HWaddr 02:42:CF:8B:46:FC
inet addr:10.114.104.1 Bcast:10.114.104.127 Mask:255.255.255.128
wlan0 Link encap:Ethernet HWaddr DC:A6:32:47:FC:F1
inet addr:192.168.1.113 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::29ff:d733:de44:39ad/64 Scope:Link
RX packets:4573 errors:0 dropped:0 overruns:0 frame:0
TX packets:2999 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:864941 (844.6 KiB) TX bytes:492376 (480.8 KiB)
From that output, we can see that the eth0 interface (the ethernet) is indeed working and received a unique IP, but for some reason it only received an IPv6 and not an IPv4. This could be related to your router, as the wlan0 interface (wifi) receives a proper IPv4 IP and thus you can connect, use balena scan, etc. Can you please share the router model/manufacturer?
The router is Asus ac68u.
For some reason, your router’s DHCP server is not assigning an IPv4 to the device via ethernet. This could be isolated to the particular ethernet port that your are using, or in general your router could be configured not to assign IPv4 via ethernet. I would advise to check the user’s manual and see how to reset the DHCP server configuration to the default.
Thanks for using the forums and we hope that you enjoy balena! Best of luck
