i want to push the masterclass example image with “hello world” webserver.
The push is not done because the manifest is unknown, how can i solve it?
Hello, the example may have become slightly outdated because we no longer have an image for Node 8, however you should be able to use FROM balenalib/revpi-connect-4-node:18 to pull Node 18 instead.
Let us know if that works for you, and if you don’t mind also provide the link to the page you were following so we can update the example.
