I’m trying to work on the Mult-Media audio and when I type in “balena push Multi_Media” :
[debug] handling message: {“message”:"\u001b[31m[Error]\u001b[39m Some services failed to build:",“isError”:true}
[debug] handling message: {“message”:"\u001b[31m[Error]\u001b[39m Service: main",“isError”:true}
[Error] Service: main
[debug] handling message: {“message”:"\u001b[31m[Error]\u001b[39m Error: The command ‘/bin/sh -c DEBIAN_FRONTEND=noninteractive JOBS=MAX npm install --unsafe-perm’ returned a non-zero code: 126",“isError”:true}
[Error] Error: The command ‘/bin/sh -c DEBIAN_FRONTEND=noninteractive JOBS=MAX npm install --unsafe-perm’ returned a non-zero code: 126
[debug] handling message: {“message”:"\u001b[36m[Info]\u001b[39m Built on arm03"}
[Info] Built on arm03
[debug] handling message: {“message”:"\u001b[31m[Error]\u001b[39m Not deploying release.",“isError”:true}
[Warn] Windows-format line endings were detected in some files. Consider using the --convert-eol option.
Remote build failed
RemoteBuildFailedError: Remote build failed
at Bluebird.then (C:\Program Files\balena-cli\client\build\utils\remote-build.js:60:23)
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:126:23)
From previous event:
at Object.startRemoteBuild (C:\Program Files\balena-cli\client\build\utils\remote-build.js:57:12)
at process._tickCallback (internal/process/next_tick.js:68:7)
If you need help, don’t hesitate in contacting our support forums at
https://forums.balena.io
For CLI bug reports or feature requests, have a look at the GitHub issues or
