Hi, I’m receiving the following error deployng app:
[debug] handling message: {“message”:"\u001b[31m[Error]\u001b[39m Service: influxdb",“isError”:true}
[Error] Service: influxdb
[debug] handling message: {“message”:"\u001b[31m[Error]\u001b[39m Error: The command ‘/bin/sh -c sed -i ‘s|/var/lib/influxdb|/data/influxdb|g’ /etc/influxdb/influxdb.conf’ returned a non-zero code: 1",“isError”:true}
[Error] Error: The command ‘/bin/sh -c sed -i ‘s|/var/lib/influxdb|/data/influxdb|g’ /etc/influxdb/influxdb.conf’ returned a non-zero code: 1
[debug] handling message: {“message”:"\u001b[36m[Info]\u001b[39m Built on arm01"}
[Info] Built on arm01
[debug] handling message: {“message”:"\u001b[31m[Error]\u001b[39m Not deploying release.",“isError”:true}
Remote build failed
RemoteBuildFailedError: Remote build failed
at Bluebird.then (/usr/local/lib/balena-cli/build/utils/remote-build.js:56:23)
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:126:23)
From previous event:
at Object.startRemoteBuild (/usr/local/lib/balena-cli/build/utils/remote-build.js:54:12)
at process._tickCallback (internal/process/next_tick.js:68:7)
