I’m having issues with pushing code. here is the error I’m getting. The issue started without any code change. Started yesterday, still ongoing
» balena push Staging
[debug] Using . as build source
[debug] Connecting to builder at https://builder.balena-cloud.com/v3/build?owner=tuned_apple&app=Staging&emulated=&nocache=
/ Uploading source package to balena cloud[debug] received HTTP 200 OK
[debug] handling message: {“type”:“metadata”,“resource”:“buildLogId”,“value”:XXXX}
[debug] handling message: {“message”:“\u001b[36m[Info]\u001b[39m Starting build for Staging, user tuned_apple”}
[Info] Starting build for Staging, user tuned_apple
[debug] handling message: {“message”:“\u001b[36m[Info]\u001b[39m Dashboard link: https://dashboard.balena-cloud.com/apps/XXXXX/devices”}
[Info] Dashboard link: https://dashboard.balena-cloud.com/apps/XXXXX/devices
[debug] handling message: {“message”:“\u001b[31m[Error]\u001b[39m Could not detect project type: Resolution could not be performed”,“isError”:true}
[Error] Could not detect project type: Resolution could not be performed
[debug] handling message: {“message”:“\u001b[31m[Error]\u001b[39m Not deploying release.“,”isError”:true}
RemoteBuildFailedError: Remote build failed
at Bluebird.then (/usr/local/lib/node_modules/balena-cli/build/utils/remote-build.js:63:23)
at tryCatcher (/usr/local/lib/node_modules/balena-cli/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/usr/local/lib/node_modules/balena-cli/node_modules/bluebird/js/release/promise.js:512:31)
at Promise._settlePromise (/usr/local/lib/node_modules/balena-cli/node_modules/bluebird/js/release/promise.js:569:18)
at Promise._settlePromise0 (/usr/local/lib/node_modules/balena-cli/node_modules/bluebird/js/release/promise.js:614:10)
at Promise._settlePromises (/usr/local/lib/node_modules/balena-cli/node_modules/bluebird/js/release/promise.js:694:18)
at _drainQueueStep (/usr/local/lib/node_modules/balena-cli/node_modules/bluebird/js/release/async.js:138:12)
at _drainQueue (/usr/local/lib/node_modules/balena-cli/node_modules/bluebird/js/release/async.js:131:9)
at Async._drainQueues (/usr/local/lib/node_modules/balena-cli/node_modules/bluebird/js/release/async.js:147:5)
at Immediate.Async.drainQueues [as _onImmediate] (/usr/local/lib/node_modules/balena-cli/node_modules/bluebird/js/release/async.js:17:14)
at processImmediate (timers.js:637:19)
at process.topLevelDomainCallback (domain.js:126:23)
