I am the creator of this repository: GitHub - ShiromMakkad/LedFx-balenaSound: LedFx and balenaSound With One Click!
The repository works great, but I can only deploy it when creating a new application. Whenever I try to use balena push or use the deploy to Balena button, I get the following error:
[Success] Successfully built service multiroom-client
[Success] Successfully built service bluetooth
[Success] Successfully built service upnp
[Success] Successfully built service spotify
[Success] Successfully built service audio
[Success] Successfully built service airplay
[Success] Successfully built service multiroom-server
[Success] Successfully built service sound-supervisor
[Info] Uploading images
[Error] Error:: It is necessary that each release that has a release version1 and has a status that is equal to "success" and is not invalidated, belongs to an application that owns exactly one release that has a release version2 that is equal to the release version1 and has a status that is equal to "success" and is not invalidated.
[Info] Built on arm05
[Success] Release successfully created!
[Info] Release: a56d6c4b4e5f521ab729b3e7328f5135 (id: 1732814)
[Info] Build finished in 3 minutes, 49 seconds
As you can see, it properly builds the release except for one error. Then it just doesn’t upload them. If I delete the application and rebuild it, everything works. These issues only started happening after I upgraded to a Raspberry Pi 4, I never had this problem on my 3B+. If I add my device to the repository before the first build, it fails too.
I believe this has something to do with my LedFx docker container not supporting linux/arm/v8, but it does support linux/arm/v7. Unfortunately, adding v8 support isn’t possible because Cython isn’t available for v8. Still, the image runs perfectly on a Pi 4, but Balena’s platform seems to just throw out the image instead of running it on a Pi 4.
Having to reflash or move all my devices for even minor changes is INCREDIBLY frustrating. These issues have persisted for weeks.
How can I fix this?
