Hi I posted a comment on the blog post about the live train station monitor as I’m having issues pushing the file to balena. Chris suggested posting a topic here to work out what is going wrong.
This is the full build log:
[Info] Starting build for Train_monitor, user gh_gritchie1
[Info] Dashboard link: https://dashboard.balena-cloud.com/apps/1582631/devices
[Info] Building on arm03
[Info] Pulling previous images for caching purposes...
[main] Step 1/10 : FROM balenalib/raspberrypi3-64-debian-python:3.7-buster
[main] ---> b7a18c70cfb9
[main] Step 2/10 : RUN install_packages jq moreutils libopenjp2-7 libfreetype6-dev libjpeg-dev libtiff5
[main] Using cache
[main] ---> c3be1120cede
[main] Step 3/10 : WORKDIR /usr/app
[main] Using cache
[main] ---> 99f5f67bcb75
[main] Step 4/10 : COPY ./requirements.txt .
[main] Using cache
[main] ---> c07ac08a8210
[main] Step 5/10 : RUN pip install -r requirements.txt --index-url=https://www.piwheels.org/simple
[main] ---> Running in 84f5650a599b
[main] Looking in indexes: https://www.piwheels.org/simple
[main] Collecting luma.oled
[main] Downloading https://www.piwheels.org/simple/luma-oled/luma.oled-3.4.0-py2.py3-none-any.whl
[main] Collecting timeloop
[main] Downloading https://www.piwheels.org/simple/timeloop/timeloop-1.0.2-py3-none-any.whl
[main] Collecting requests
[main] Downloading https://www.piwheels.org/simple/requests/requests-2.22.0-py2.py3-none-any.whl (57kB)
[main] Collecting luma.core>=1.12.0
[main] Downloading https://www.piwheels.org/simple/luma-core/luma.core-1.12.0-py2.py3-none-any.whl (51kB)
[main] Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1
[main] Downloading https://www.piwheels.org/simple/urllib3/urllib3-1.25.8-py2.py3-none-any.whl (125kB)
[main] Collecting chardet<3.1.0,>=3.0.2
[main] Downloading https://www.piwheels.org/simple/chardet/chardet-3.0.4-py2.py3-none-any.whl (133kB)
[main] Collecting idna<2.9,>=2.5
[main] Downloading https://www.piwheels.org/simple/idna/idna-2.8-py2.py3-none-any.whl (58kB)
[main] Collecting certifi>=2017.4.17
[main] Downloading https://www.piwheels.org/simple/certifi/certifi-2019.11.28-py2.py3-none-any.whl (156kB)
[main] ERROR: Could not find a version that satisfies the requirement pillow>=4.0.0 (from luma.core>=1.12.0->luma.oled->-r requirements.txt (line 1)) (from versions: none)
[main]
[main] ERROR: No matching distribution found for pillow>=4.0.0 (from luma.core>=1.12.0->luma.oled->-r requirements.txt (line 1))
[main]
[main] WARNING: You are using pip version 19.3.1; however, version 20.0.2 is available.
[main] You should consider upgrading via the 'pip install --upgrade pip' command.
[main]
[main] Removing intermediate container 84f5650a599b
[main] The command '/bin/sh -c pip install -r requirements.txt --index-url=https://www.piwheels.org/simple' returned a non-zero code: 1
[Info] Uploading images
[Error] Service: main
[Error] Error: The command '/bin/sh -c pip install -r requirements.txt --index-url=https://www.piwheels.org/simple' returned a non-zero code: 1
[Info] Built on arm03
Remote build failed
variable: "set DEBUG=1" on a Windows command prompt, "$env:DEBUG = 1" on
powershell, or "export DEBUG=1" on Linux or macOS.
https://forums.balena.io
For CLI bug reports or feature requests, have a look at the GitHub issues or
Hopefully this helps identify the issue.
Gregor
