I can connect through the terminal to the device, but even after restarting the raspberry shows always VPN Only mode.
When I run the command balena ps -a in terminal it says that i should check if the docker deamon is running. It seems like some systemservices are not running correctly, and when I restart them manually, they still through an error.
I have seen similar topics like this, but they seem all to relate to a full storage, what does not apply to me.
Has anybody experienced similar problems? Is there something i can do, apart from reinstalling it from scratch?
