I successfully installed an instance of OpenBalena, I added to devices and also push and cross-compile a multicontainer app.
Less fortunate, when I tried the balena device public-url enable, I got the following error:
BalenaRequestError: Request error: Internal Server Error
at /usr/local/lib/node_modules/balena-cli/node_modules/balena-request/build/request.js:197:17
From previous event:
at /usr/local/lib/node_modules/balena-cli/node_modules/balena-request/build/request.js:189:62
at Object.exports.send (/usr/local/lib/node_modules/balena-cli/node_modules/balena-request/build/request.js:188:8)
at /usr/local/lib/node_modules/balena-cli/node_modules/balena-pine/build/pine.js:90:24
at BalenaPine._request (/usr/local/lib/node_modules/balena-cli/node_modules/balena-pine/build/pine.js:89:10)
at BalenaPine.PinejsClientCoreFactory.PinejsClientCore.request (/usr/local/lib/node_modules/balena-cli/node_modules/pinejs-client-core/core.js:979:29)
at BalenaPine.PinejsClientCoreTemplate.patch (/usr/local/lib/node_modules/balena-cli/node_modules/pinejs-client-core/core.js:798:21)
at /usr/local/lib/node_modules/balena-cli/node_modules/balena-sdk/build/models/device.js:1934:19
at runCallback (timers.js:810:20)
at tryOnImmediate (timers.js:768:5)
at processImmediate [as _immediateCallback] (timers.js:745:5)
at Object.exports.enableDeviceUrl (/usr/local/lib/node_modules/balena-cli/node_modules/balena-sdk/build/models/device.js:1933:8)
at Command.action (/usr/local/lib/node_modules/balena-cli/build/actions/device.js:179:33)
at /usr/local/lib/node_modules/balena-cli/node_modules/capitano/build/command.js:98:37
at
any idea?
