I am trying to flash an image to SD which has been formatted on a MacOS using SDHC formatting app. The Mac OS is 10.15 Catalina and the Etcher version is 1.5.59. I can select the .img file and the SD card without a problem - but it fails immediately after I attempt the FLASH operation. The error box invites me to ask you on here for guidance. Many thanks in advance
Same issue. Dead in the water…
Hi and welcome both,
We’re currently updating Etcher to be notarized which is currently needed for apps to run on macOS Catalina.
What you can try to do is actually open Etcher with sudo as suggested here while we work on it.
If it still doesn’t work, you can open the devtools by pressing cmd + opt + i and switching to the Console tab to check the logs and tell us if you see any error (in my experience with this issue, it should be EPERM), or paste the logs if you want us to take a look.
Many thank for your prompt response - I will try one of the options you suggest probably start with the SUDO command line.
Kind regards
Hi
I have the same problem, the error is EPERM. Wait for the repaired version
Hello @Ludovika
Welcome to the forums!
This issue was fixed in Etcher v1.5.61. Can you please update to the latest version of Etcher and see if the issue is resolved for you?
Regards,
Rahul
