Restarting service 'main XXXXXccXXXXXXX'
main *** Resin Machine Info:
main *** Type: None
main *** Arch: None
main *******************
main *** Configuration:
main GW_EUI: XXXXXXXXXXX
main Enabling TTN gateway connector
main ERROR: GW_KEY required
main See https://www.thethingsnetwork.org/docs/gateways/registration.html#via-gateway-connector
Service exited 'main XXXXXccXXXXXXX'
main *** Type: None
main *** Arch: None
main GW_EUI: XXXXXXXXXXXXXXXXX
I deleted the gw_key variable, in your howto isn’t it set also …
Thats the kick … the release was the old release of the gateway.
But now i have these problem error in the log:
Gateway EUI: b827ebfffeb7f6de
main Using MODEL: RAK2245
main Server: wss://eu1.cloud.thethings.network:8887
main Resetting gateway concentrator on GPIO 17
main 2021-06-24 12:00:23.572 [SYS:INFO] Logging : stderr (maxsize=10000000, rotate=3)
main 2021-06-24 12:00:23.572 [SYS:INFO] Station Ver : 2.0.5(rpi/std) 2021-06-24 11:56:02
main 2021-06-24 12:00:23.573 [SYS:INFO] Package Ver : 1.0.0
main 2021-06-24 12:00:23.573 [SYS:INFO] proto EUI : XXXXXXXXX (/sys/class/net/eth0/address)
main 2021-06-24 12:00:23.573 [SYS:INFO] prefix EUI : ::1 (builtin)
main 2021-06-24 12:00:23.573 [SYS:INFO] Station EUI : b827:ebff:feb7:f6de
main 2021-06-24 12:00:23.573 [SYS:INFO] Station home: ./ (builtin)
main 2021-06-24 12:00:23.573 [SYS:INFO] Station temp: /var/tmp/ (builtin)
main 2021-06-24 12:00:23.573 [SYS:WARN] Station in NO-CUPS mode
main 2021-06-24 12:00:23.776 [TCE:INFO] Starting TC engine
main 2021-06-24 12:00:23.777 [any:ERRO] Parsing trust certificate: PEM - PEM string is not as expected : BASE64 - Invalid character in input
main 2021-06-24 12:00:23.777 [AIO:ERRO] tc trust certificates rejected by MBedTLS
main 2021-06-24 12:00:23.777 [TCE:INFO] INFOS reconnect backoff 0s (retry 0)
main 2021-06-24 12:00:23.777 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
main 2021-06-24 12:00:33.779 [any:ERRO] Parsing trust certificate: PEM - PEM string is not as expected : BASE64 - Invalid character in input
main 2021-06-24 12:00:33.779 [AIO:ERRO] tc trust certificates rejected by MBedTLS
main 2021-06-24 12:00:33.779 [TCE:INFO] INFOS reconnect backoff 20s (retry 2)
main 2021-06-24 12:00:53.781 [any:ERRO] Parsing trust certificate: PEM - PEM string is not as expected : BASE64 - Invalid character in input
main 2021-06-24 12:00:53.781 [AIO:ERRO] tc trust certificates rejected by MBedTLS
main 2021-06-24 12:00:53.781 [TCE:INFO] INFOS reconnect backoff 30s (retry 3)
main 2021-06-24 12:01:23.782 [any:ERRO] Parsing trust certificate: PEM - PEM string is not as expected : BASE64 - Invalid character in input
main 2021-06-24 12:01:23.782 [AIO:ERRO] tc trust certificates rejected by MBedTLS
main 2021-06-24 12:01:23.783 [TCE:INFO] INFOS reconnect backoff 40s (retry 4)
main 2021-06-24 12:02:03.784 [any:ERRO] Parsing trust certificate: PEM - PEM string is not as expected : BASE64 - Invalid character in input
main 2021-06-24 12:02:03.784 [AIO:ERRO] tc trust certificates rejected by MBedTLS
main 2021-06-24 12:02:03.784 [TCE:INFO] INFOS reconnect backoff 50s (retry 5)
main 2021-06-24 12:02:53.786 [any:ERRO] Parsing trust certificate: PEM - PEM string is not as expected : BASE64 - Invalid character in input
main 2021-06-24 12:02:53.786 [AIO:ERRO] tc trust certificates rejected by MBedTLS
main 2021-06-24 12:02:53.786 [TCE:INFO] INFOS reconnect backoff 60s (retry 6)
main 2021-06-24 12:03:53.787 [any:ERRO] Parsing trust certificate: PEM - PEM string is not as expected : BASE64 - Invalid character in input
main 2021-06-24 12:03:53.787 [AIO:ERRO] tc trust certificates rejected by MBedTLS
main 2021-06-24 12:03:53.787 [TCE:INFO] INFOS reconnect backoff 60s (retry 7)
main 2021-06-24 12:04:53.789 [any:ERRO] Parsing trust certificate: PEM - PEM string is not as expected : BASE64 - Invalid character in input
main 2021-06-24 12:04:53.789 [AIO:ERRO] tc trust certificates rejected by MBedTLS
main 2021-06-24 12:04:53.789 [TCE:INFO] INFOS reconnect backoff 60s (retry 8)
main 2021-06-24 12:05:53.790 [any:ERRO] Parsing trust certificate: PEM - PEM string is not as expected : BASE64 - Invalid character in input
