Pi Supply LoRA Gateway HAT with Basic Station TTN
Hello!
I have a Pi Supply LoRa Gateway HAT 915MHz (model is a RAK2247 HAT), and followed this guide: https://www.balena.io/blog/deploy-a-basics-station-lora-gateway-with-ttn-and-balena/
I have changed the specifications to comply with the correct reset pins based off specifications:
However, I get the following error:
12.07.22 17:19:19 (-0700) <basicstation> Gateway EUI: e45f01fffe677a92
12.07.22 17:19:20 (-0700) <basicstation> Using MODEL: SX1301
12.07.22 17:19:20 (-0700) <basicstation> Server: wss://nam1.cloud.thethings.network:8887
12.07.22 17:19:20 (-0700) <basicstation> Resetting gateway concentrator on GPIO 22
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.296 [SYS:INFO] findDefaultEui -> protoEuiSrc /sys/class/net/wlan0/address - protoEUI 251096696584851
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.298 [SYS:INFO] Logging     : stderr (maxsize=10000000, rotate=3)
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.298 [SYS:INFO] Station Ver : 2.0.5(rpi/std) 2022-07-06 19:21:43
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.298 [SYS:INFO] Package Ver : 1.0.0
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.298 [SYS:INFO] proto EUI(x) : 0:e45f:167:7a93	(/sys/class/net/wlan0/address)
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.298 [SYS:INFO] prefix EUI  : ::1	(builtin)
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.298 [SYS:INFO] Station EUI : e45f:1ff:fe67:7a93
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.298 [SYS:INFO] Station home: ./	(builtin)
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.298 [SYS:INFO] Station temp: /var/tmp/	(builtin)
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.298 [SYS:WARN] Station in NO-CUPS mode
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.500 [TCE:INFO] Starting TC engine
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.502 [any:INFO] ./tc.trust:
12.07.22 17:19:23 (-0700) <basicstation> cert. version     : 3
12.07.22 17:19:23 (-0700) <basicstation> serial number     : 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
12.07.22 17:19:23 (-0700) <basicstation> issuer name       : O=Digital Signature Trust Co., CN=DST Root CA X3
12.07.22 17:19:23 (-0700) <basicstation> subject name      : O=Digital Signature Trust Co., CN=DST Root CA X3
12.07.22 17:19:23 (-0700) <basicstation> issued  on        : 2000-09-30 21:12:19
12.07.22 17:19:23 (-0700) <basicstation> expires on        : 2021-09-30 14:01:15
12.07.22 17:19:23 (-0700) <basicstation> signed using      : RSA with SHA1
12.07.22 17:19:23 (-0700) <basicstation> RSA key size      : 2048 bits
12.07.22 17:19:23 (-0700) <basicstation> basic constraints : CA=true
12.07.22 17:19:23 (-0700) <basicstation> key usage         : Key Cert Sign, CRL Sign
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.502 [AIO:INFO] tc has no cert configured - running server auth and client auth with token
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.561 [TCE:INFO] Connecting to INFOS: wss://nam1.cloud.thethings.network:8887
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.782 [TCE:ERRO] Infos error: ::0 Failed to fetch gateway: error:pkg/gatewayserver:gateway_eui_not_registered (gateway EUI `E45F01FFFE677A93` is not registered)
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.782 [AIO:DEBU] [3] ws_close reason=1000
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.782 [AIO:ERRO] Recv failed: SSL - The peer notified us that the connection is going to be closed
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.782 [AIO:DEBU] [3] WS connection shutdown...
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.783 [TCE:INFO] INFOS reconnect backoff 0s (retry 0)
12.07.22 17:19:23 (-0700) <basicstation> 2022-07-13 00:19:23.784 [any:INFO] ./tc.trust:
A balena team member posted a solution here by deploying this repo. Using the same variables and redeploying with the suggested repo took care of the incorrect EUI “not registered”, but I still came across an issue:
2.07.22 17:32:19 (-0700) <basicstation> GATEWAY_EUI: E45F01FFFE677A92
12.07.22 17:32:20 (-0700) <basicstation> parse error: Invalid numeric literal at EOF at line 1, column 12
12.07.22 17:32:20 (-0700) <basicstation> ------------------------------------------------------------------
12.07.22 17:32:20 (-0700) <basicstation> Protocol
12.07.22 17:32:20 (-0700) <basicstation> Mode:          DYNAMIC
12.07.22 17:32:20 (-0700) <basicstation> Protocol:      LNS
12.07.22 17:32:20 (-0700) <basicstation> LNS Server:    wss://nam1.cloud.thethings.network:8887
12.07.22 17:32:20 (-0700) <basicstation> Main NIC:      eth0
12.07.22 17:32:20 (-0700) <basicstation> Gateway EUI:   E45F01FFFE677A92
12.07.22 17:32:20 (-0700) <basicstation> Radio
12.07.22 17:32:20 (-0700) <basicstation> Model:         SX1301
12.07.22 17:32:20 (-0700) <basicstation> Concentrator:  SX1301
12.07.22 17:32:20 (-0700) <basicstation> Design:        V2
12.07.22 17:32:20 (-0700) <basicstation> Radio Device:  /dev/spidev0.0
12.07.22 17:32:20 (-0700) <basicstation> Interface:     SPI
12.07.22 17:32:20 (-0700) <basicstation> SPI Speed:     2000000
12.07.22 17:32:20 (-0700) <basicstation> Reset GPIO:    22
12.07.22 17:32:20 (-0700) <basicstation> Enable GPIO:   0
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.003 [SYS:INFO] Logging     : stderr (maxsize=10000000, rotate=3)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.004 [SYS:INFO] Station Ver : 2.0.6(rpi/stdn) 2022-06-17 14:47:13
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.004 [SYS:INFO] Package Ver : (null)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.004 [SYS:INFO] mbedTLS Ver : 2.28.0
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.005 [SYS:INFO] proto EUI   : e45f:1ff:fe67:7a92	(station.conf)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.005 [SYS:INFO] prefix EUI  : ::1	(builtin)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.005 [SYS:INFO] Station EUI : e45f:1ff:fe67:7a92
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.005 [SYS:INFO] Station home: ./	(builtin)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.006 [SYS:INFO] Station temp: /var/tmp/	(builtin)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.006 [SYS:WARN] Station in NO-CUPS mode
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.012 [RAL:DEBU] execvp argv[0]: </proc/self/exe>
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.012 [RAL:DEBU]        argv[1]: <-S>
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.012 [RAL:DEBU]        argv[2]: <(null)>
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.017 [S00:INFO] Logging     : stderr (maxsize=10000000, rotate=3)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.017 [S00:INFO] Station Ver : 2.0.6(rpi/stdn) 2022-06-17 14:47:13
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.018 [S00:INFO] Package Ver : (null)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.018 [S00:INFO] mbedTLS Ver : 2.28.0
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.019 [S00:INFO] proto EUI   : e45f:1ff:fe67:7a92	(station.conf)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.019 [S00:INFO] prefix EUI  : ::1	(builtin)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.020 [S00:INFO] Station EUI : e45f:1ff:fe67:7a92
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.020 [S00:INFO] Station home: ./	(builtin)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.021 [S00:INFO] Station temp: /var/tmp/	(builtin)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.021 [S00:INFO] Station slave: 0
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.021 [S00:WARN] Station in NO-CUPS mode
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.022 [S00:INFO] Slave LGW (0) - started.
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.012 [RAL:INFO] Master has started slave: pid=46 idx=0 (attempt 1)
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.211 [TCE:INFO] Starting TC engine
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.280 [AIO:INFO] ./tc.trust:
12.07.22 17:32:21 (-0700) <basicstation> cert. version     : 3
12.07.22 17:32:21 (-0700) <basicstation> serial number     : 04:00:00:00:00:01:15:4B:5A:C3:94
12.07.22 17:32:21 (-0700) <basicstation> issuer name       : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA
12.07.22 17:32:21 (-0700) <basicstation> subject name      : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA
12.07.22 17:32:21 (-0700) <basicstation> issued  on        : 1998-09-01 12:00:00
12.07.22 17:32:21 (-0700) <basicstation> expires on        : 2028-01-28 12:00:00
12.07.22 17:32:21 (-0700) <basicstation> signed using      : RSA with SHA1
12.07.22 17:32:21 (-0700) <basicstation> RSA key size      : 2048 bits
12.07.22 17:32:21 (-0700) <basicstation> basic constraints : CA=true
12.07.22 17:32:21 (-0700) <basicstation> key usage         : Key Cert Sign, CRL Sign
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.280 [TCE:INFO] Connecting to INFOS: wss://nam1.cloud.thethings.network:8887
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.644 [TCE:INFO] Infos: e45f:1ff:fe67:7a92 muxs-::0 wss://nam1.cloud.thethings.network:8887/traffic/eui-E45F01FFFE677A92
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.645 [AIO:DEBU] [4] ws_close reason=1000
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.645 [AIO:ERRO] Recv failed: SSL - The peer notified us that the connection is going to be closed
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.645 [AIO:DEBU] [4] WS connection shutdown...
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.711 [AIO:INFO] ./tc.trust:
12.07.22 17:32:21 (-0700) <basicstation> 2022-07-13 00:32:21.711 [TCE:VERB] Connecting to MUXS...
12.07.22 17:32:22 (-0700) <basicstation> 2022-07-13 00:32:22.076 [AIO:ERRO] [4] WS upgrade failed with HTTP status code: 400
12.07.22 17:32:22 (-0700) <basicstation> 2022-07-13 00:32:22.076 [AIO:DEBU] [4] WS connection shutdown...
12.07.22 17:32:22 (-0700) <basicstation> 2022-07-13 00:32:22.076 [TCE:VERB] Connection to MUXS closed in state 3
12.07.22 17:32:22 (-0700) <basicstation> 2022-07-13 00:32:22.076 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
Both deployment of repos showed the device online in Balena but “disconnected” on TTN. I am new to using Balena OS along with TTN (I have mostly been using LoRa P2P) so any advice is definitely appreciated!
Hello @daaz welcome to the balena community!
Could you please confirm that with the 2nd deployment you registered again the gateway using the EUI E45F01FFFE677A92 at TTN? Did you change the TC_KEY?
wow…registering again for the 2nd deployment seemed to do the trick! Thank you @mpous. The gateway is now connected with time sync rejection issues that were brought up from that previous post
Here is the log upon connection:
13.07.22 10:02:51 (-0700) <basicstation> GATEWAY_EUI: E45F01FFFE677A92
13.07.22 10:02:51 (-0700) <basicstation> parse error: Invalid numeric literal at EOF at line 1, column 12
13.07.22 10:02:51 (-0700) <basicstation> ------------------------------------------------------------------
13.07.22 10:02:51 (-0700) <basicstation> Protocol
13.07.22 10:02:51 (-0700) <basicstation> Mode:          DYNAMIC
13.07.22 10:02:51 (-0700) <basicstation> Protocol:      LNS
13.07.22 10:02:51 (-0700) <basicstation> LNS Server:    wss://nam1.cloud.thethings.network:8887
13.07.22 10:02:51 (-0700) <basicstation> Main NIC:      eth0
13.07.22 10:02:51 (-0700) <basicstation> Gateway EUI:   E45F01FFFE677A92
13.07.22 10:02:51 (-0700) <basicstation> Radio
13.07.22 10:02:51 (-0700) <basicstation> Model:         SX1301
13.07.22 10:02:51 (-0700) <basicstation> Concentrator:  SX1301
13.07.22 10:02:51 (-0700) <basicstation> Design:        V2
13.07.22 10:02:51 (-0700) <basicstation> Radio Device:  /dev/spidev0.0
13.07.22 10:02:51 (-0700) <basicstation> Interface:     SPI
13.07.22 10:02:51 (-0700) <basicstation> SPI Speed:     2000000
13.07.22 10:02:51 (-0700) <basicstation> Reset GPIO:    22
13.07.22 10:02:51 (-0700) <basicstation> Enable GPIO:   0
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.889 [SYS:INFO] Logging     : stderr (maxsize=10000000, rotate=3)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.889 [SYS:INFO] Station Ver : 2.0.6(rpi/stdn) 2022-06-17 14:47:13
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.889 [SYS:INFO] Package Ver : (null)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.889 [SYS:INFO] mbedTLS Ver : 2.28.0
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.889 [SYS:INFO] proto EUI   : e45f:1ff:fe67:7a92	(station.conf)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.889 [SYS:INFO] prefix EUI  : ::1	(builtin)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.889 [SYS:INFO] Station EUI : e45f:1ff:fe67:7a92
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.889 [SYS:INFO] Station home: ./	(builtin)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.889 [SYS:INFO] Station temp: /var/tmp/	(builtin)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.889 [SYS:WARN] Station in NO-CUPS mode
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.893 [RAL:DEBU] execvp argv[0]: </proc/self/exe>
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.893 [RAL:DEBU]        argv[1]: <-S>
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.893 [RAL:DEBU]        argv[2]: <(null)>
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.900 [S00:INFO] Logging     : stderr (maxsize=10000000, rotate=3)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.900 [S00:INFO] Station Ver : 2.0.6(rpi/stdn) 2022-06-17 14:47:13
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.900 [S00:INFO] Package Ver : (null)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.900 [S00:INFO] mbedTLS Ver : 2.28.0
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.900 [S00:INFO] proto EUI   : e45f:1ff:fe67:7a92	(station.conf)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.901 [S00:INFO] prefix EUI  : ::1	(builtin)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.901 [S00:INFO] Station EUI : e45f:1ff:fe67:7a92
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.902 [S00:INFO] Station home: ./	(builtin)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.902 [S00:INFO] Station temp: /var/tmp/	(builtin)
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.902 [S00:INFO] Station slave: 0
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.902 [S00:WARN] Station in NO-CUPS mode
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.903 [S00:INFO] Slave LGW (0) - started.
13.07.22 10:02:51 (-0700) <basicstation> 2022-07-13 17:02:51.893 [RAL:INFO] Master has started slave: pid=45 idx=0 (attempt 1)
13.07.22 10:02:52 (-0700) <basicstation> 2022-07-13 17:02:52.092 [TCE:INFO] Starting TC engine
13.07.22 10:02:52 (-0700) <basicstation> 2022-07-13 17:02:52.159 [AIO:INFO] ./tc.trust:
13.07.22 10:02:52 (-0700) <basicstation> cert. version     : 3
13.07.22 10:02:52 (-0700) <basicstation> serial number     : 04:00:00:00:00:01:15:4B:5A:C3:94
13.07.22 10:02:52 (-0700) <basicstation> issuer name       : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA
13.07.22 10:02:52 (-0700) <basicstation> subject name      : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA
13.07.22 10:02:52 (-0700) <basicstation> issued  on        : 1998-09-01 12:00:00
13.07.22 10:02:52 (-0700) <basicstation> expires on        : 2028-01-28 12:00:00
13.07.22 10:02:52 (-0700) <basicstation> signed using      : RSA with SHA1
13.07.22 10:02:52 (-0700) <basicstation> RSA key size      : 2048 bits
13.07.22 10:02:52 (-0700) <basicstation> basic constraints : CA=true
13.07.22 10:02:52 (-0700) <basicstation> key usage         : Key Cert Sign, CRL Sign
13.07.22 10:02:52 (-0700) <basicstation> 2022-07-13 17:02:52.160 [TCE:INFO] Connecting to INFOS: wss://nam1.cloud.thethings.network:8887
13.07.22 10:02:52 (-0700) <basicstation> 2022-07-13 17:02:52.609 [TCE:INFO] Infos: e45f:1ff:fe67:7a92 muxs-::0 wss://nam1.cloud.thethings.network:8887/traffic/eui-E45F01FFFE677A92
13.07.22 10:02:52 (-0700) <basicstation> 2022-07-13 17:02:52.609 [AIO:DEBU] [4] ws_close reason=1000
13.07.22 10:02:52 (-0700) <basicstation> 2022-07-13 17:02:52.609 [AIO:ERRO] Recv failed: SSL - The peer notified us that the connection is going to be closed
13.07.22 10:02:52 (-0700) <basicstation> 2022-07-13 17:02:52.610 [AIO:DEBU] [4] WS connection shutdown...
13.07.22 10:02:52 (-0700) <basicstation> 2022-07-13 17:02:52.676 [AIO:INFO] ./tc.trust:
13.07.22 10:02:52 (-0700) <basicstation> 2022-07-13 17:02:52.676 [TCE:VERB] Connecting to MUXS...
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.358 [TCE:VERB] Connected to MUXS.
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.489 [S00:VERB] ./reset.sh: Forked, waiting...
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.489 [S00:DEBU] execvp argv[0]: <./reset.sh>
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.490 [S00:DEBU]        argv[1]: </dev/spidev0.0>
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.490 [S00:DEBU]        argv[2]: <0>
13.07.22 10:02:53 (-0700) <basicstation> Concentrator reset through GPIO17
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [RAL:INFO] Region plan hwspec 'sx1301/1' mapped to 1 slaves 'sx1301/1'
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [RAL:INFO] Master sending 645 bytes of JSON sx1301conf to slave (0)
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO] Configuring for region: US915 -- 923.0MHz..928.0MHz
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR0  SF10/BW125
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR1  SF9/BW125
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR2  SF8/BW125
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR3  SF7/BW125
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR4  SF8/BW500
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR5  FSK
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR6  FSK
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR7  FSK
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR8  SF12/BW500
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR9  SF11/BW500
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR10 SF10/BW500
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR11 SF9/BW500
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR12 SF8/BW500
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR13 SF7/BW500
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR14 FSK
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   DR15 FSK
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   TX power: 26.0 dBm EIRP
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   JoinEui list: 0 entries
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   NetID filter: FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.479 [S2E:INFO]   Dev/test settings: nocca=1 nodc=1 nodwell=1
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.826 [S00:INFO] Process ./reset.sh (pid=46) completed
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.826 [S00:INFO] Lora gateway library version: Version: 5.0.1;
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.828 [S00:INFO] [LGW lgw1] clksrc=1 lorawan_public=1
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.829 [S00:INFO]  RX/TX RF0:    904.3MHz rssi_offset=-166.0 type=2 tx_notch_freq=0
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.829 [S00:INFO]  RX    RF1:    905.0MHz rssi_offset=-166.0 type=2 tx_notch_freq=0
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.829 [S00:INFO]  [mSF]   0:    903.9MHz rf=0 freq=-400.0 datarate=0
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.829 [S00:INFO]  [mSF]   1:    904.1MHz rf=0 freq=-200.0 datarate=0
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.829 [S00:INFO]  [mSF]   2:    904.3MHz rf=0 freq=  +0.0 datarate=0
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.829 [S00:INFO]  [mSF]   3:    904.5MHz rf=0 freq=+200.0 datarate=0
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.829 [S00:INFO]  [mSF]   4:    904.7MHz rf=1 freq=-300.0 datarate=0
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.829 [S00:INFO]  [mSF]   5:    904.9MHz rf=1 freq=-100.0 datarate=0
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.829 [S00:INFO]  [mSF]   6:    905.1MHz rf=1 freq=+100.0 datarate=0
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.829 [S00:INFO]  [mSF]   7:    905.3MHz rf=1 freq=+300.0 datarate=0
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.829 [S00:INFO]  [STD]   8:    904.6MHz rf=0 freq=+300.0 datarate=4 bw=1
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.830 [S00:INFO]  channel 9 disabled
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.830 [S00:INFO] SX130x LBT not enabled
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.830 [S00:INFO] Station device: /dev/spidev0.0 (PPS capture disabled)
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.830 [S00:INFO] [lgw_spi_open:101] Setting SPI speed to 2000000
13.07.22 10:02:53 (-0700) <basicstation> 2022-07-13 17:02:53.830 [S00:INFO] [lgw_spi_open:135] Note: SPI port opened and configured ok
13.07.22 10:02:57 (-0700) <basicstation> 2022-07-13 17:02:57.155 [S00:INFO] Concentrator started (3s325ms)
13.07.22 10:03:39 (-0700) <basicstation> 2022-07-13 17:03:39.159 [SYN:INFO] MCU/SX130X drift stats: min: +0.0ppm  q50: +1.0ppm  q80: +7.6ppm  max: +13.3ppm - threshold q90: +9.5ppm
13.07.22 10:03:39 (-0700) <basicstation> 2022-07-13 17:03:39.159 [SYN:INFO] Mean MCU drift vs SX130X#0: 1.0ppm
13.07.22 10:03:56 (-0700) <basicstation> 2022-07-13 17:03:55.965 [SYN:INFO] Time sync qualities: min=73 q90=171 max=175 (previous q90=2147483647)
13.07.22 10:04:01 (-0700) <basicstation> 2022-07-13 17:04:01.217 [SYN:VERB] Time sync rejected: quality=173 threshold=171
13.07.22 10:04:19 (-0700) <basicstation> 2022-07-13 17:04:19.073 [SYN:INFO] MCU/SX130X drift stats: min: +0.0ppm  q50: -3.6ppm  q80: +10.0ppm  max: -14.8ppm - threshold q90: -13.8ppm
13.07.22 10:04:19 (-0700) <basicstation> 2022-07-13 17:04:19.073 [SYN:INFO] Mean MCU drift vs SX130X#0: 0.1ppm
13.07.22 10:04:25 (-0700) <basicstation> 2022-07-13 17:04:25.375 [SYN:VERB] Time sync rejected: quality=174 threshold=171
13.07.22 10:04:48 (-0700) <basicstation> 2022-07-13 17:04:48.074 [S00:DEBU] [CRC FAIL] 905.300MHz -11.50/-105.0 SF7/BW125 (mod=16/dr=2/bw=3) xtick=06c6ed94 (113700244) 163 bytes: 8B439BBEAEABB49C320A7711AF72E3C446C7423567D287C0E26802D7BD391BC11F0AEF4258364191F14C8E47AF98F557ECB01A1190161927AA1B2802836ED52B..
13.07.22 10:04:56 (-0700) <basicstation> 2022-07-13 17:04:56.885 [SYN:INFO] Time sync qualities: min=102 q90=171 max=174 (previous q90=171)
13.07.22 10:05:03 (-0700) <basicstation> 2022-07-13 17:05:03.187 [SYN:INFO] MCU/SX130X drift stats: min: +0.0ppm  q50: +2.4ppm  q80: +9.5ppm  max: +12.9ppm - threshold q90: -11.9ppm
13.07.22 10:05:03 (-0700) <basicstation> 2022-07-13 17:05:03.187 [SYN:INFO] Mean MCU drift vs SX130X#0: 0.6ppm
13.07.22 10:05:22 (-0700) <basicstation> 2022-07-13 17:05:22.094 [SYN:VERB] Time sync rejected: quality=198 threshold=171
13.07.22 10:05:34 (-0700) <basicstation> 2022-07-13 17:05:34.698 [SYN:VERB] Time sync rejected: quality=207 threshold=171
13.07.22 10:05:48 (-0700) <basicstation> 2022-07-13 17:05:48.353 [SYN:INFO] MCU/SX130X drift stats: min: +0.0ppm  q50: -4.0ppm  q80: +9.5ppm  max: -23.8ppm - threshold q90: +11.9ppm
13.07.22 10:05:48 (-0700) <basicstation> 2022-07-13 17:05:48.353 [SYN:INFO] Mean MCU drift vs SX130X#0: 0.1ppm
13.07.22 10:05:58 (-0700) <basicstation> 2022-07-13 17:05:58.856 [SYN:INFO] Time sync qualities: min=99 q90=171 max=207 (previous q90=171)
13.07.22 10:06:17 (-0700) <basicstation> 2022-07-13 17:06:17.762 [SYN:VERB] Time sync rejected: quality=191 threshold=171
13.07.22 10:06:25 (-0700) <basicstation> 2022-07-13 17:06:25.440 [S00:DEBU] [CRC FAIL] 904.300MHz -11.25/-102.0 SF7/BW125 (mod=16/dr=2/bw=3) xtick=0c94b9ab (211073451) 149 bytes: 7AB11D1852E908D7E592F0E5C693583036539E2F3BB76BDB843185C4DFD3DE656B7B96DB54F999C3950BF7270D0AD62E70B853336C3A8E349BA6CC3D3DBDD714..
13.07.22 10:06:32 (-0700) <basicstation> 2022-07-13 17:06:32.466 [SYN:INFO] MCU/SX130X drift stats: min: +0.0ppm  q50: -3.8ppm  q80: -10.0ppm  max: +11.4ppm - threshold q90: +10.5ppm
13.07.22 10:06:32 (-0700) <basicstation> 2022-07-13 17:06:32.466 [SYN:INFO] Mean MCU drift vs SX130X#0: 1.0ppm
13.07.22 10:07:01 (-0700) <basicstation> 2022-07-13 17:07:01.875 [SYN:INFO] Time sync qualities: min=69 q90=169 max=191 (previous q90=171)
I will start testing this with some nodes. For anybody who has purchased the Pi Supply IoT LoRa Gateway HAT 915Mhz, (RAK2247):
Repo: https://github.com/xoseperez/basicstation
GW_RESET_GPIO is 22
GW_RESET_PIN is 15 (deprecated)
TC_KEY can be directly copied from TTN, without need to remove the leading added letters.
Hello @daaz sometimes i had the same behaviour on my gateways. I usually restarted from balenaCloud the gateway or leave it like that during some time and worked again. Let me know what do work for you!
BTW I found this ticket on the original repo, however i’m not sure about the solution.
