Hi, I’m trying to flash a USB drive to install Lubuntu in an old Macbook. I’m using Etcher 1.19 on a M1 iMac running Sonoma. Etcher appears to run and I get the “successfully completed” message at the end but it fact the USB is useless. Regardless of whether it’s initially formatted as exFAT or MacOS extended, the USB disappears (un-mounts) from the desktop during flashing and it does not re-mount when the flashing is “complete.” Using Disk Utility I see a small partition labelled “ESP” in the USB which can be mounted manually. Inside this partition there is an EFI folder but it has only 4 MB inside instead of the entire Lubuntu package which should be over 1 GB. If I put the USB in another Mac, it does not mount. Any thought? Alternatives to Etcher? Thanks for your help.
Related topics
Topic | Replies | Views | Activity | |
Flash Failed...HELP!! | 9 | 6920 | November 2, 2021 | |
After Flashing OS images to USB drives, the other partition are not readable anymore | 2 | 644 | January 24, 2023 | |
Balena destroyed my USB drive ! How to recover? | 10 | 10006 | October 2, 2021 | |
Attention. Something went wrong. If it is a compressed ......... | 26 | 10907 | August 4, 2024 | |
No working files on USB after flashing Linux USB on Mac Ventura | 3 | 363 | February 26, 2023 |
