Using:
Etcher 1.4.4
Windows 7.0
Flash fails
LOG:
etcher:sdk:scanner subscribe +0ms USBBootAdapter
gui.js:105081 _____ _ _
| | | | | | ___ _ __
| || / | ’ \ / _ \ '|
_/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@resin.io
Version = 1.4.4, Type = nsis
gui.js:105081 Mon Jun 11 2018 22:26:56 GMT-0700 (Pacific Daylight Time) Application start ({“packageType”:“nsis”,“version”:“1.4.4”})
gui.js:105081 Mon Jun 11 2018 22:26:56 GMT-0700 (Pacific Daylight Time) Checking for updates ({“currentVersion”:“1.4.4”,“stable”:true,“updateSemverRange”:"<2.0.0",“includeUnstableChannel”:false})
gui.js:105081 etcher:sdk:scanner start +86ms true
gui.js:105081 Mon Jun 11 2018 22:26:57 GMT-0700 (Pacific Daylight Time) Update notification skipped ({“reason”:“Latest version”})
gui.js:105081 Mon Jun 11 2018 22:26:58 GMT-0700 (Pacific Daylight Time) [object Event]
gui.js:105081 Mon Jun 11 2018 22:48:34 GMT-0700 (Pacific Daylight Time) Open external link ({“url”:“https://github.com/resin-io/etcher/blob/master/SUPPORT.md”})
gui.js:105081 Mon Jun 11 2018 22:49:23 GMT-0700 (Pacific Daylight Time) Open image selector
gui.js:105081 Mon Jun 11 2018 22:49:29 GMT-0700 (Pacific Daylight Time) Select image ({“path”:“F:\ARCHIVE\APPS\00.OS\2018-04-18-raspbian-stretch.zip”,“size”:{“original”:4953473024,“final”:{“estimation”:false,“value”:4953473024}},“extension”:“img”,“archiveExtension”:“zip”,“hasMBR”:true,“hasGPT”:false,“partitions”:[{“type”:12,“id”:null,“name”:null,“firstLBA”:8192,“lastLBA”:96454,“extended”:false},{“type”:131,“id”:null,“name”:null,“firstLBA”:98304,“lastLBA”:9674752,“extended”:false},{“type”:0,“id”:null,“name”:null,“firstLBA”:0,“lastLBA”:0,“extended”:false},{“type”:0,“id”:null,“name”:null,“firstLBA”:0,“lastLBA”:0,“extended”:false}],“logo”:false,“bmap”:false})
gui.js:105081 Mon Jun 11 2018 22:49:35 GMT-0700 (Pacific Daylight Time) Open modal ({“name”:“drive-selector”})
gui.js:105081 Mon Jun 11 2018 22:49:38 GMT-0700 (Pacific Daylight Time) Toggle drive ({“drive”:{“size”:127865454592,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive4",“error”:null,“isReadOnly”:false,“displayName”:“N:\”,“blockSize”:512,“adapter”:“blockdevice”,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive4",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“mountpoints”:[{“path”:“N:\”}],“description”:“Generic STORAGE DEVICE USB Device”,“isUAS”:false},“previouslySelected”:false})
gui.js:105081 Mon Jun 11 2018 22:49:40 GMT-0700 (Pacific Daylight Time) Modal accepted ({“name”:“drive-selector”})
gui.js:105081 Mon Jun 11 2018 22:49:41 GMT-0700 (Pacific Daylight Time) Open modal ({“name”:“warning”})
gui.js:105081 Mon Jun 11 2018 22:49:49 GMT-0700 (Pacific Daylight Time) Modal accepted ({“name”:“warning”,“value”:true})
gui.js:105081 etcher:sdk:scanner stop +23m true
gui.js:105081 Mon Jun 11 2018 22:49:49 GMT-0700 (Pacific Daylight Time) Flashing 0 devices, 0% at 0 MB/s (total 0 MB/s) eta in undefineds with 0 failed devices
gui.js:105081 Mon Jun 11 2018 22:49:49 GMT-0700 (Pacific Daylight Time) Flash ({“image”:“F:\ARCHIVE\APPS\00.OS\2018-04-18-raspbian-stretch.zip”,“drives”:["\\.\PhysicalDrive4"],“uuid”:“bb50aa6c-7eeb-4edc-af9b-baf24f0146ad”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true})
gui.js:105081 Elevating command: C:\Users\xxx\AppData\Local\Programs\etcher\Etcher.exe C:\Users\xxx\AppData\Local\Programs\etcher\resources\app.asar
gui.js:105081 Successfully connected to IPC server: etcher-server-14660, socket root C:\Users\xxx\AppData\Local\Temp
gui.js:105081 Image: 2018-04-18-raspbian-stretch.zip
gui.js:105081 Devices: \.\PhysicalDrive4
gui.js:105081 Umount on success: true
gui.js:105081 Validate on success: true
gui.js:105081 Mon Jun 11 2018 22:50:02 GMT-0700 (Pacific Daylight Time) Flashing 1 devices, 0% at 0 MB/s (total 0 MB/s) eta in 0s with 0 failed devices
gui.js:105081 Mon Jun 11 2018 22:50:02 GMT-0700 (Pacific Daylight Time) Flashing 1 devices, 0% at 5.6 MB/s (total 5.6 MB/s) eta in 876.3976724314135s with 0 failed devices
gui.js:105081 Mon Jun 11 2018 22:50:03 GMT-0700 (Pacific Daylight Time) Flashing 1 devices, 0% at 9.3 MB/s (total 9.3 MB/s) eta in 532.7190066643481s with 0 failed devices
working…
gui.js:105081 Mon Jun 11 2018 22:52:30 GMT-0700 (Pacific Daylight Time) Flashing 1 devices, 47% at 15.9 MB/s (total 15.9 MB/s) eta in 164.5984349258649s with 0 failed devices
gui.js:105081 Mon Jun 11 2018 22:52:31 GMT-0700 (Pacific Daylight Time) Flashing 1 devices, 47% at 16 MB/s (total 16 MB/s) eta in 163.26167076167076s with 0 failed devices
gui.js:105081 Fail: Object
gui.js:105081 Error: EIO: i/o error, write
gui.js:105081 Mon Jun 11 2018 22:52:31 GMT-0700 (Pacific Daylight Time) Input/output error ({“image”:“2018-04-18-raspbian-stretch.zip”,“drives”:["\\.\PhysicalDrive4"],“uuid”:“bb50aa6c-7eeb-4edc-af9b-baf24f0146ad”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true})
gui.js:105081 Mon Jun 11 2018 22:52:31 GMT-0700 (Pacific Daylight Time) Open modal ({“name”:“warning”})
gui.js:105081 etcher:sdk:scanner start +3m true
gui.js:105081 Flash results Object
gui.js:105081 Terminating IPC server
gui.js:105081 Mon Jun 11 2018 22:52:45 GMT-0700 (Pacific Daylight Time) Modal rejected ({“name”:“warning”,“method”:“backdrop click”})
