Please don't trap me at the "Restarting Device" page
The restart button
traps me with the Restarting [Name]… info screen
When I have multiple devices to restart this can be annoying. Could this be something I click to acknowledge and I can bypass?
Hi. One possibility is using the balena-cli restart command. Just be careful if you are doing too many requests per second as the API has rate limits.
Either backgrounding the restart task (using bash’s &), or xargs with -P should do the job nicely
I’ll stick with hitting the restart button next to each container, that ends up being a bit faster because I can leave to a different page and do it there.
Hi again @cnr,
I’ll open an issue for our UI team to take a look at.
Thanks for reporting this.
James.
+1 from me.
The fullscreen overlay is disruptive / annoying, esp. when you want to monitor the restart procedure in the logs.
Thank
Thanks for the feedback @fritz, it’s highly appreciated.
We’ve shared the request with our product and UI teams.
Hey @cnr,
as a workaround, in case you need to restart multiple devices, you can select multiple devices from the device list and issue a restart from the actions dropdown menu.
That’ still non-escapable, but it will allow you to issue multiple devices restarts at once.
