Hi there, I have search the forum before post and try several similar solutions but i still have the same problem. i have use 2 different SD cards and have exactly the same problem. I am trying to flash Hoobs image to sd card and after validating the card at the end i get flash failed message and in windows notification popup the following message:
"Something went wrong while writing HOOBS-3.3.1-ARM7.img to Generic SD16G SD Card (E:). electron.app.balenaEtcher "
Below is the console if someone can understand anything that can help:
Verifying 1 device, 100% at 17.80 MB/s (total 17.80 MB/s) eta in 0s with 0 failed devices
gui.js:42737 Tue Mar 02 2021 10:31:18 GMT+0200 (Eastern European Standard Time) Flash error ({“image”:{“size”:2692743168,“name”:“HOOBS-3.3.1-ARM7.img”,“hasMBR”:true,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:2420113408,“type”:131,“index”:2}],“extension”:“img”,“path”:“C:\Users\chris\Downloads\HOOBS-armv7\HOOBS-3.3.1-ARM7.img”},“drives”:[{“size”:62662901760,“isVirtual”:false,“enumerator”:“SD”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive2",“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:4096,“isSCSI”:true,“isRemovable”:true,“device”:"\\.\PhysicalDrive2",“busVersion”:“1.0”,“isSystem”:false,“busType”:“SD”,“isCard”:true,“isUSB”:false,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:“Generic SD16G SD Card”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“d6c55a78-e298-41ab-a40f-08b835366cb9”,“flashInstanceUuid”:“d6c55a78-e298-41ab-a40f-08b835366cb9”,“error”:{“name”:“Error”,“message”:“Unmount failed”,“stack”:“Error: Unmount failed”},“sample”:0.1,“applicationSessionUuid”:“fa2f0174-9b54-4c2f-bd92-5ab30f49c08b”,“flashingWorkflowUuid”:“a362e49f-a303-48ac-91cd-5093831a2c79”})
gui.js:42737 Finish: 2290089984
gui.js:42737 Terminating IPC server
gui.js:42737 Flash results Object
gui.js:42737 Tue Mar 02 2021 10:31:19 GMT+0200 (Eastern European Standard Time) Done ({“image”:{“size”:2692743168,“name”:“HOOBS-3.3.1-ARM7.img”,“hasMBR”:true,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:2420113408,“type”:131,“index”:2}],“extension”:“img”,“path”:“C:\Users\chris\Downloads\HOOBS-armv7\HOOBS-3.3.1-ARM7.img”},“drives”:[{“size”:62662901760,“isVirtual”:false,“enumerator”:“SD”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive2",“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:4096,“isSCSI”:true,“isRemovable”:true,“device”:"\\.\PhysicalDrive2",“busVersion”:“1.0”,“isSystem”:false,“busType”:“SD”,“isCard”:true,“isUSB”:false,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:“Generic SD16G SD Card”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“d6c55a78-e298-41ab-a40f-08b835366cb9”,“status”:“finished”,“flashInstanceUuid”:“d6c55a78-e298-41ab-a40f-08b835366cb9”,“errors”:[{“name”:“Error”,“description”:“Generic SD16G SD Card”,“device”:"\\.\PhysicalDrive2"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:2290089984,“sourceMetadata”:{“size”:2692743168,“name”:“HOOBS-3.3.1-ARM7.img”,“blocks”:[{“blocks”:[{“offset”:0,“length”:342884352}]},{“blocks”:[{“offset”:406847488,“length”:139460608}]},{“blocks”:[{“offset”:550502400,“length”:266338304}]},{“blocks”:[{“offset”:817889280,“length”:1184890880}]},{“blocks”:[{“offset”:2003828736,“length”:249561088}]},{“blocks”:[{“offset”:2291138560,“length”:3145728}]},{“blocks”:[{“offset”:2318401536,“length”:30408704}]},{“blocks”:[{“offset”:2353004544,“length”:73400320}]}],“blockmappedSize”:2290089984},“sample”:0.1,“applicationSessionUuid”:“fa2f0174-9b54-4c2f-bd92-5ab30f49c08b”,“flashingWorkflowUuid”:“a362e49f-a303-48ac-91cd-5093831a2c79”})
gui.js:42737 Tue Mar 02 2021 10:31:20 GMT+0200 (Eastern European Standard Time) SafeWebview loaded ({“event”:{“id”:21,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.5.116&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1614673880109.477,“resourceType”:“mainFrame”,“ip”:“3.64.200.242”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“57877”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“gzip”],“content-length”:[“6556”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Mon, 01 Mar 2021 16:26:43 GMT”],“etag”:["“08c0396b52852a8c811980eb04c9ecd0-ssl-df”"],“link”:["</webpack-runtime-6dd3e65b41cbde0459f8.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-149d8dfa392460762009.js>; rel=preload; as=script, </50c25a04-a68e3217d6ce65727bd7.js>; rel=preload; as=script, </73ad3401-ecb0d3613fde52e78ca5.js>; rel=preload; as=script, </532a2f07-f1ad28da1825cfcce2c7.js>; rel=preload; as=script, </app-45108b8eda43e368eee2.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7dd2f2b2e7.js>; rel=preload; as=script, </ec1189df-f1a321eba12a2bb0c7ab.js>; rel=preload; as=script, </a9a7754c-29508ff4045f1f93a5f6.js>; rel=preload; as=script, </commons-b3fb9651c57d1d917e54.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-0a6ab80bc309b84cac96.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin"],“referrer-policy”:[“strict-origin-when-cross-origin”],“server”:[“Netlify”],“status”:[“200”],“strict-transport-security”:[“max-age=31536000”],“vary”:[“Accept-Encoding”],“x-content-type-options”:[“nosniff”],“x-frame-options”:[“DENY”],“x-nf-request-id”:[“3a9609f0-326d-42e8-aeb3-64e220d7aeab-33639541”],“x-xss-protection”:[“1; mode=block”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“fa2f0174-9b54-4c2f-bd92-5ab30f49c08b”,“flashingWorkflowUuid”:“a362e49f-a303-48ac-91cd-5093831a2c79”})
