Every time I try to install OMV 5 or 4 for HC-1, the installation stop 5 second into install with an error that it cannot continue. I find the flash drive bricked. I then have to repartion and reformat to recover the 32gb Micro SD card. What am I doing wrong.-1584843108742.log (28.3 KB)
Hi there, we have noticed that there is a permission error in the logs, can you check if “Controlled folder access” (assuming you are on Windows) is enabled, and if so, if an exception is added for Etcher. If not, you will need to add an exception for Etcher.
