Hi, I installed BalenaSound into a Raspberry PI 2 (with a WiFi dongle) successfully.
From the logs it seems that the music streaming is correcting addressed to the PI, but no sound comes from the amplifier.
This is the log:
17.04.20 17:40:53 (+0200) airplay Device is discoverable as “balenaSound Airplay 1069”
17.04.20 17:41:32 (+0200) airplay Error 6 opening the pipe named “/var/cache/snapcast/snapfifo”: “No such device or address”.
17.04.20 17:41:53 (+0200) snapcast-client 2020-04-17 15-41-53 [Info] (Alsa) frames: 1324
17.04.20 17:41:54 (+0200) snapcast-server 2020-04-17 15-41-54 [Info] (onStateChanged) onStateChanged (default): 2
17.04.20 17:41:54 (+0200) snapcast-client 2020-04-17 15-41-54 [Info] (Stream) Chunk: 0 0 0 0 1 59 0
17.04.20 17:41:55 (+0200) snapcast-client 2020-04-17 15-41-55 [Info] (Stream) Chunk: 0 0 0 0 7 89 0
17.04.20 17:41:56 (+0200) snapcast-client 2020-04-17 15-41-56 [Info] (Stream) Chunk: 0 0 0 0 33 59 0
17.04.20 17:41:57 (+0200) snapcast-client 2020-04-17 15-41-57 [Info] (Stream) Chunk: 0 0 0 0 57 89 0
17.04.20 17:41:57 (+0200) snapcast-server 2020-04-17 15-41-57 [Info] (onStateChanged) onStateChanged (default): 1
17.04.20 17:41:58 (+0200) snapcast-client 2020-04-17 15-41-58 [Info] (Stream) Chunk: 0 0 0 0 82 59 0
17.04.20 17:41:59 (+0200) snapcast-client 2020-04-17 15-41-59 [Info] (Stream) Chunk: 0 0 0 0 107 59 0
17.04.20 17:41:59 (+0200) snapcast-client 2020-04-17 15-41-59 [Info] (getPlayerChunk) Exception
Music is played via airplay from a MacBook Pro. I see the device from MAc.
I use the same cable for other music devices and it works fine. Volume is up. The song isn’t paused but I can’t hear it.
Can anyone help me?
Luca
