I see no services listed on the balenaSound Device Summary Tab. (No airplay, audio, bluetooth…)
I see no bluetooth or Airplay client on my network - from the balenaSound device.
Any thoughts on how to access the services view / fix bluetooth & Airplay broadcast? (example)
I did a fresh deployment via a SD card flash from balenaCloud.
On the first boot, the device had two IPs and two MAC addresses.
I resolved this by ‘restart services’ and then ‘reboot’ via balenaCloud.
However, no services view or services being broadcast.
Hey @adamsiem first of all welcome to the balena forums
So how did you deploy balenaSound to the device? Have you downloaded and pushed the code from the original repo?
There are multiple ways to push the balenaSound application to your device. Cloning the repo and pushing it via balena push is one way of doing it: https://github.com/balenalabs/balena-sound
There is also the Deploy with Balena button that streamlines the push as you don’t need to download the repo.
Also, what do you mean by the balenaSound UI? Do you mean the balenaCloud dashboard where you would see the different services and be able to set environment variables?
