I have a rpi4 in use for a balenaSound project that was working fine until I updated the OS from 2.7.3 to 9.1.0. After updating the OS I’m not getting any sound out of the 3.5 mm jack (which was working right up until the OS update and the stereo is still working).
There are some spicy looking logs for the audio service:
audio
audio — Audio —
audio Starting audio service with settings:
audio - pulseaudio 15.0
audio - Pulse log level: NOTICE
audio - Default output: AUTO
audio - Default volume: 75%
audio
audio Detected audio cards:
audio 0 Headphones bcm2835_headpho-bcm2835Headphones
audio
audio
audio Setting audio routing rules…
audio Routing ‘balena-sound.input’ to ‘snapcast’.
audio Routing ‘balena-sound.output’ to ‘alsa_output.bcm2835-jack.stereo-fallback’.
audio W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
audio E: [alsa-sink-bcm2835 Headphones] alsa-sink.c: ALSA woke us up to write new data to the device, but there was actually nothing to write.
audio E: [alsa-sink-bcm2835 Headphones] alsa-sink.c: Most likely this is a bug in the ALSA driver ‘(null)’. Please report this issue to the ALSA developers.
audio E: [alsa-sink-bcm2835 Headphones] alsa-sink.c: We were woken up with POLLOUT set – however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
audio E: [pulseaudio] module-loopback.c: No such sink.
audio E: [pulseaudio] module.c: Failed to load module “module-loopback” (argument: “latency_msec=200 source=balena-sound.output.monitor sink=alsa_output.bcm2835-jack.stereo-fallback”): initialization failed.
audio E: [pulseaudio] main.c: Sink alsa_output.bcm2835-jack.stereo-fallback does not exist.
audio W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
audio W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
