I have a similar issue to many posts on this topic, but I have not found any solutions that work for me.
I am 100% confident that the speakers are not the issue, I unplugged them from my daily use PC straight into the PI and still no audio.
I am using an RPI4 with BalenaOS. I installed via CLI with a customized yml file that has PiHole services added to it. I used this guide to get started: https://www.balena.io/blog/two-projects-one-device-turn-your-raspberry-pi-into-a-multitool/. It requires BalenaSound to run on a different port, I chose 8080, which is set in the variables.
I am able to connect with Spotify and AirPlay, but no audio plays and then the connection breaks after a little bit.
I’ve tried the following:
- set AUDIO-OUTPUT variable to RPI_HEADPHONES
- set SOUND_MODE to STANDALONE
- running PULSE_SINK=alsa_output.bcm2835-jack.stereo-fallback paplay /usr/share/sounds/alsa/Front_Center.wav - this returns a “Stream error: No such entity”
- running PULSE_SINK=balena-sound.output paplay /usr/share/sounds/alsa/Front_Center.wav - this didn’t return any error or play any sounds
- re-deploying the image
I have seen error messages in the logs like:
12.05.22 17:08:13 (-0400) audio WARNING: BCM2835 audio card not found, are you sure you are running on a Raspberry Pi?
12.05.22 17:08:13 (-0400) audio Setting audio routing rules…
12.05.22 17:08:13 (-0400) audio Routing ‘balena-sound.input’ to ‘balena-sound.output’.
12.05.22 17:08:13 (-0400) audio Routing ‘balena-sound.output’ to ‘0’.
12.05.22 17:08:13 (-0400) audio W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
12.05.22 17:08:14 (-0400) audio E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
12.05.22 17:08:14 (-0400) audio E: [pulseaudio] module.c: Failed to load module “module-alsa-card” (argument: "device_id=“0” name=“platform-fef00700.hdmi” card_name=“alsa_card.platform-fef00700.hdmi” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=yes card_properties=“module-udev-detect.discovered=1"”): initialization failed.
12.05.22 17:08:14 (-0400) audio E: [pulseaudio] module.c: Failed to load module “module-alsa-card” (argument: "device_id=“1” name=“platform-fef05700.hdmi” card_name=“alsa_card.platform-fef05700.hdmi” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=yes card_properties=“module-udev-detect.discovered=1"”): initialization failed.
12.05.22 17:08:14 (-0400) Service exited ‘multiroom-client sha256:ab0f2f2839f602d57da4d5d1f1a2f4a93bbb147bc048cc2008ef3a6adc13a585’
Not sure if another PulseAudio update caused this or what, but I have been digging into this for a while and I’m at a loss.
EDIT:
Initial output from PulseAudio -vvvvv shows errors like “Error opening PCM device hw:1: No such file or directory” over and over, “skipping profile”, “caching failure”, etc.
