No audio from 3.5mm running 32-bit OS on RPi 3
I’ve perused the seemingly related topics, and am aware of the bug in 64-bit OS, but I downloaded the armv7hf 32-bit, and everything appeared to go swimmingly.
However, I’m not getting audio from the 3.5mm output, and I’m finding it difficult to troubleshoot. The speaker is tested, the audio port “crackles” when it reboots. But other than that, there’s no sound emitting from any of the options, neither Airplay, Bluetooth, nor Spotify Connect.
I’ve attempted to run amixer and speaker-test, but in both cases I get command not found - I’m doing this via the Dashboard OS terminal.
I was also getting
[Fatal] (Snapclient) Exception: No audio player support for: pulse
but can’t find any documentation about what that means, or if it’s related.
Aside from the 32-bit solutions, I’m not seeing anything that fits my case.
Does anybody have any tips on troubleshooting this issue?
Hello, are you having this issue with the 64 bit or 32 bit OS? If it’s the 64 bit, have you tried removing the vc4-kms-v3d overlay from the “Define DT overlays” setting on the dashboard? (see No sound output with balenaOS 64 bit on Raspberry Pi 3 · Issue #82 · balenalabs/balena-sound · GitHub) Otherwise, please provide the OS version you’re using.
Thanks, @alanb128 . Like the title states, I’m running the 32-bit OS (the default for RPi3). The image I used with Etcher is balena-cloud-balena-sound-raspberrypi3-2.80.3+rev1-v12.7.0, and the Host OS Version on dashboard, likewise, says balenaOS 2.80.3+rev1. Does that answer the question? Am I correct in ascertaining the operating system as 32-bit?
Well this is odd, Jon. I just tested a Pi3, 32-bit, version 2.80.3+rev1 with Supervisor 12.7.0 myself, and it worked great within minutes of deploying it. I built the project by clicking the blue “Deploy with Balena” button located on the GitHub repo, and once it finished building and downloading the containers, I used my laptop, loaded Bluetooth settings, scanned for devices, found the Pi3, connected to it, browsed to YouTube and started playing a video, and audio came out of the headphones I had attached to the Pi3 3.5mm audio jack.
So, let’s check some basics here. First, are all the containers built and running properly? It should look like this:
Next, make sure the headphones are plugged prior to powering up the Pi. Sometimes the Pi doesnt like to “recognize” new speakers being plugged in after it has already booted. And press them all the way in, mine you have to give a firm push on. Finally, what kind of an SD Card do you have. I have noticed they can be very finicky and the faster the SD Card, the better.
@dtischler, thank you for the reply.
I’m running 2.80.3+rev1 with supervisor version 12.8.8.
Services appear to be in good shape from my end. I see our release numbers are different, and the Supervisor versions are different.
I booted up with the speaker connected to the 3.5mm audio jack, and the logs read like it should be playing - that the Spotify client is playing on the RPi, albeit lots of errors on the multiroom services:
Rebooting
Supervisor starting
 airplay  Starting AirPlay plugin...
 airplay  Device name: balenaSound AirPlay 5455
 airplay  Shairport-sync started. Device is discoverable as balenaSound AirPlay 5455
 airplay  fatal error: pa context is not good -- the error message "Connection terminated".
 spotify  Starting Spotify plugin...
 spotify  Device name: balenaSound Spotify 5455
 spotify  Volume normalization enabled.
 spotify  Spotify audio cache disabled.
 spotify  [2021-06-29T17:07:22Z INFO  librespot] librespot (raspotify v0.16.0) 0adb851 (2020-12-15). Built on 2020-12-30. Build ID: KLdkAvgt
 spotify  [2021-06-29T17:07:23Z INFO  librespot_core::session] Connecting to AP "guc3-accesspoint-a-26lq.ap.spotify.com:4070"
 spotify  [2021-06-29T17:07:24Z INFO  librespot_core::session] Authenticated as "jonmitten" !
 spotify  [2021-06-29T17:07:24Z INFO  librespot_playback::audio_backend::alsa] Using alsa sink
 spotify  [2021-06-29T17:07:24Z INFO  librespot_core::session] Country: "US"
 multiroom-client
 multiroom-client  --- Multiroom ---
 multiroom-client  Starting multiroom service with settings:
 multiroom-client  - Mode: server
 multiroom-client  - Snapcast version: v0.25.0
 multiroom-client  Waiting for sound supervisor to start at 172.17.0.1:80
 multiroom-client  Starting multi-room client...
 multiroom-client  - balenaSound mode: MULTI_ROOM
 multiroom-client  - Target snapcast server: 192.168.0.68
 multiroom-client  2021-06-29 17-07-40.616 [Error] (Snapclient) PCM device "default" not found
 multiroom-client  2021-06-29 17-07-40.678 [Error] (Connection) Error reading message header of length 0: End of file
 multiroom-client  2021-06-29 17-07-40.678 [Error] (Connection) Error in socket shutdown: Socket not connected
 multiroom-client  2021-06-29 17-07-40.678 [Error] (Connection) Failed to send message, error: Bad file descriptor
 multiroom-client  2021-06-29 17-07-40.678 [Error] (Controller) Time sync request failed: Bad file descriptor
 multiroom-client  2021-06-29 17-07-41.746 [Error] (Connection) Error reading message header of length 0: End of file
 multiroom-client  2021-06-29 17-07-41.747 [Error] (Connection) Error in socket shutdown: Socket not connected
 multiroom-client  2021-06-29 17-07-41.747 [Error] (Connection) Failed to send message, error: Bad file descriptor
 multiroom-client  2021-06-29 17-07-41.747 [Error] (Controller) Time sync request failed: Bad file descriptor
 multiroom-client  2021-06-29 17-07-42.678 [Error] (Controller) Failed to send hello request, error: Operation timed out
 multiroom-client  2021-06-29 17-07-42.678 [Error] (Controller) Time sync request failed: Operation timed out
 multiroom-client  2021-06-29 17-07-43.679 [Error] (Connection) Failed to connect to host '192.168.0.68', error: Connection refused
 multiroom-client  2021-06-29 17-07-43.679 [Error] (Controller) Error: Connection refused
 multiroom-client  2021-06-29 17-07-43.679 [Error] (Connection) Error in socket shutdown: Socket not connected
 multiroom-client  2021-06-29 17-07-43.747 [Error] (Controller) Failed to send hello request, error: Operation timed out
 multiroom-client  2021-06-29 17-07-43.747 [Error] (Controller) Time sync request failed: Operation timed out
 multiroom-client  2021-06-29 17-07-44.748 [Error] (Connection) Failed to connect to host '192.168.0.68', error: Connection refused
 multiroom-client  2021-06-29 17-07-44.748 [Error] (Controller) Error: Connection refused
 multiroom-client  2021-06-29 17-07-44.748 [Error] (Connection) Error in socket shutdown: Socket not connected
 multiroom-client  2021-06-29 17-07-47.755 [Error] (Controller) Failed to send hello request, error: Operation timed out
 multiroom-client  2021-06-29 17-07-47.756 [Error] (Controller) Time sync request failed: Operation timed out
 multiroom-client  2021-06-29 17-07-47.756 [Error] (Connection) Error reading message header of length 0: Operation canceled
 multiroom-client  2021-06-29 17-07-48.765 [Error] (Connection) Error reading message header of length 0: End of file
 multiroom-client  2021-06-29 17-07-48.765 [Error] (Connection) Error in socket shutdown: Socket not connected
 multiroom-client  2021-06-29 17-07-48.765 [Error] (Connection) Failed to send message, error: Bad file descriptor
 multiroom-client  2021-06-29 17-07-48.765 [Error] (Controller) Time sync request failed: Bad file descriptor
 multiroom-client  2021-06-29 17-07-49.774 [Error] (Connection) Error reading message header of length 0: End of file
 multiroom-client  2021-06-29 17-07-49.774 [Error] (Connection) Error in socket shutdown: Socket not connected
 multiroom-client  2021-06-29 17-07-49.774 [Error] (Connection) Failed to send message, error: Bad file descriptor
 multiroom-client  2021-06-29 17-07-49.774 [Error] (Controller) Time sync request failed: Bad file descriptor
 logging    % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
 logging                                   Dload  Upload   Total   Spent    Left  Speed
    0      0      0 --:--:-- --:--:-- --:--:--     0curl: (6) Could not resolve host: PATCH
 logging  curl: (7) Failed to connect to 127.0.0.1 port 48484: Connection refused
 bluetooth  Running balena base image entrypoint...
 bluetooth  --- Bluetooth ---
 bluetooth  Starting bluetooth service with settings:
 bluetooth  - Device name: balenaOS 5455
 bluetooth  - HCI interface: hci0
 bluetooth  - Pairing mode: SSP
 bluetooth  - PIN code: 0000
 bluetooth  Available HCI interfaces: hci0
 bluetooth  Resetting hci0
 bluetooth  Configuring selected interface: hci0
 bluetooth  hci0 Set Connectable complete, settings: powered connectable ssp br/edr le secure-conn
 bluetooth  hci0 Set Bondable complete, settings: powered connectable bondable ssp br/edr le secure-conn
 bluetooth  hci0 Set Discoverable complete, settings: powered connectable discoverable bondable ssp br/edr le secure-conn
 bluetooth  hci0 Set Secure Simple Pairing complete, settings: powered connectable discoverable bondable ssp br/edr le secure-conn
 bluetooth  Pairing mode set to 'Secure Simple Pairing Mode (SSPM)'. PIN code is NOT required.
 bluetooth  Bluetooth agent started!
 bluetooth  Checking for known bluetooth devices...
 bluetooth  - Attempting to reconnect to Jon Mittenâs iPhone XR (FC:18:3C:6F:AB:16)...
 bluetooth  - Bluetooth profile not available or not initialized. Retrying (attempt 1/5)...
 bluetooth  - Bluetooth profile not available or not initialized. Retrying (attempt 2/5)...
 bluetooth  - Bluetooth profile not available or not initialized. Retrying (attempt 3/5)...
 bluetooth  - Bluetooth profile not available or not initialized. Retrying (attempt 4/5)...
 bluetooth  - Bluetooth profile not available or not initialized. Retrying (attempt 5/5)...
 sound-supervisor
 sound-supervisor  > sound-supervisor@1.0.0 start /usr/src
 sound-supervisor  > node build/index.js
 sound-supervisor
 sound-supervisor  Sound supervisor listening on port 80
 sound-supervisor  Error connecting to audio block - Retry failed: connect ECONNREFUSED 192.168.0.68:4317
 multiroom-server
 multiroom-server  --- Multiroom ---
 multiroom-server  Starting multiroom service with settings:
 multiroom-server  - Mode: server
 multiroom-server  - Snapcast version: v0.25.0
 multiroom-server  Waiting for sound supervisor to start at 172.17.0.1:80
Warning: Suppressed 28 message(s) due to slow reading
 audio  Routing 'balena-sound.input' to 'snapcast'.
 audio  Routing 'balena-sound.output' to 'alsa_output.bcm2835-jack.stereo-fallback'.
 audio  curl: (7) Failed to connect to 10.114.104.1 port 48484: Connection refused
 audio
 audio  --- Audio ---
 audio  Starting audio service with settings:
 audio  - pulseaudio 13.0
 audio  - Pulse log level: NOTICE
 audio  - Default output: RPI_HEADPHONES
 audio
 audio  Detected audio cards:
 audio  0 bcm2835-jack bcm2835_headphonbcm2835Headphones-bcm2835Headphones
 audio
 audio
 multiroom-client  2021-06-29 17-07-51.767 [Error] (Connection) Failed to connect to host '192.168.0.68', error: Connection refused
 multiroom-client  2021-06-29 17-07-51.767 [Error] (Controller) Error: Connection refused
 multiroom-client  2021-06-29 17-07-51.767 [Error] (Connection) Error in socket shutdown: Socket not connected
 multiroom-client  2021-06-29 17-07-51.774 [Error] (Controller) Failed to send hello request, error: Operation timed out
 multiroom-client  2021-06-29 17-07-51.774 [Error] (Controller) Time sync request failed: Operation timed out
 bluetooth  - Could not connect to Jon Mittenâs iPhone XR (FC:18:3C:6F:AB:16)...
 multiroom-server
 multiroom-server  Starting multi-room server...
 multiroom-server  2021-06-29 17-07-54.604 [Error] (Avahi) Failed to create client: Daemon not running
 multiroom-server  ALSA lib pulse.c:242:(pulse_connect) PulseAudio: Unable to connect: Connection refused
 multiroom-server
 multiroom-server  2021-06-29 17-07-54.624 [Error] (Snapserver) Exception: Can't open device 'pulse', error: Connection refused
 multiroom-client  2021-06-29 17-07-54.781 [Error] (Controller) Failed to send hello request, error: Operation timed out
 multiroom-client  2021-06-29 17-07-54.781 [Error] (Controller) Time sync request failed: Operation timed out
Service exited 'multiroom-server sha256:3776d56898f4e6d8b384ce52fe18ea201c8c249c7060244224f804372df57f7a'
 multiroom-client  2021-06-29 17-07-54.782 [Error] (Connection) Error reading message header of length 0: Operation canceled
 multiroom-client  2021-06-29 17-07-55.788 [Error] (Connection) Error reading message header of length 0: End of file
 multiroom-client  2021-06-29 17-07-55.788 [Error] (Connection) Error in socket shutdown: Socket not connected
 multiroom-client  2021-06-29 17-07-55.788 [Error] (Connection) Failed to send message, error: Bad file descriptor
 multiroom-client  2021-06-29 17-07-55.788 [Error] (Controller) Time sync request failed: Bad file descriptor
Restarting service 'multiroom-server sha256:3776d56898f4e6d8b384ce52fe18ea201c8c249c7060244224f804372df57f7a'
 multiroom-client  2021-06-29 17-07-56.789 [Error] (Connection) Failed to connect to host '192.168.0.68', error: Connection refused
 multiroom-client  2021-06-29 17-07-56.789 [Error] (Controller) Error: Connection refused
 multiroom-client  2021-06-29 17-07-56.789 [Error] (Connection) Error in socket shutdown: Socket not connected
 multiroom-client  2021-06-29 17-07-57.787 [Error] (Controller) Failed to send hello request, error: Operation timed out
 multiroom-client  2021-06-29 17-07-57.787 [Error] (Controller) Time sync request failed: Operation timed out
 audio  Setting audio routing rules...
 audio  OKW: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
 audio  W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
 audio  W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
 multiroom-server
 multiroom-server  2021-06-29 17-07-59.561 [Error] (Avahi) Failed to create client: Daemon not running
 multiroom-client  metadata:{"STREAM":"balenaSound"}
 multiroom-client  2021-06-29 17-07-59.843 [Fatal] (Snapclient) Exception: No audio player support for: pulse
 multiroom-server  2021-06-29 17-07-59.843 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
Service exited 'multiroom-client sha256:9f3361d7bf3a9dfa615264b3bc2e0dba48a3281d017043f180deaca83b059f3c'
Restarting service 'multiroom-client sha256:9f3361d7bf3a9dfa615264b3bc2e0dba48a3281d017043f180deaca83b059f3c'
 multiroom-client
 multiroom-client  2021-06-29 17-08-04.043 [Error] (Snapclient) PCM device "default" not found
 multiroom-server  2021-06-29 17-08-04.060 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
 multiroom-client  2021-06-29 17-08-04.060 [Fatal] (Snapclient) Exception: No audio player support for: pulse
 sound-supervisor  Connected to PulseAudio at 192.168.0.68:4317
 sound-supervisor  Server protocol version: 33
 sound-supervisor  Client protocol version: 33
 multiroom-client
 multiroom-client  2021-06-29 17-08-07.970 [Error] (Snapclient) PCM device "default" not found
 multiroom-server  2021-06-29 17-08-07.991 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
 multiroom-client  2021-06-29 17-08-07.991 [Fatal] (Snapclient) Exception: No audio player support for: pulse
 sound-supervisor  Joining the fleet, requesting master info with fleet-sync...
 multiroom-client
 multiroom-client  2021-06-29 17-08-11.997 [Error] (Snapclient) PCM device "default" not found
 multiroom-client  2021-06-29 17-08-12.019 [Fatal] (Snapclient) Exception: No audio player support for: pulse
 multiroom-server  2021-06-29 17-08-12.021 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
 multiroom-client
 multiroom-client  2021-06-29 17-08-16.362 [Error] (Snapclient) PCM device "default" not found
 multiroom-client  2021-06-29 17-08-16.385 [Fatal] (Snapclient) Exception: No audio player support for: pulse
 multiroom-server  2021-06-29 17-08-16.385 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
 multiroom-client
 multiroom-client  2021-06-29 17-08-21.382 [Error] (Snapclient) PCM device "default" not found
 multiroom-client  2021-06-29 17-08-21.400 [Fatal] (Snapclient) Exception: No audio player support for: pulse
 multiroom-server  2021-06-29 17-08-21.402 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
 multiroom-client
 multiroom-client  2021-06-29 17-08-28.369 [Error] (Snapclient) PCM device "default" not found
 multiroom-server  2021-06-29 17-08-28.404 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
 multiroom-client  2021-06-29 17-08-28.404 [Fatal] (Snapclient) Exception: No audio player support for: pulse
 multiroom-client
 multiroom-client  2021-06-29 17-08-38.548 [Error] (Snapclient) PCM device "default" not found
 multiroom-client  2021-06-29 17-08-38.566 [Fatal] (Snapclient) Exception: No audio player support for: pulse
 multiroom-server  2021-06-29 17-08-38.566 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
 multiroom-client
 multiroom-client  2021-06-29 17-08-54.818 [Error] (Snapclient) PCM device "default" not found
 multiroom-server  2021-06-29 17-08-54.844 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
 multiroom-client  2021-06-29 17-08-54.844 [Fatal] (Snapclient) Exception: No audio player support for: pulse
 multiroom-client
 multiroom-client  2021-06-29 17-09-23.763 [Error] (Snapclient) PCM device "default" not found
 multiroom-server  2021-06-29 17-09-23.784 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
 multiroom-client  2021-06-29 17-09-23.784 [Fatal] (Snapclient) Exception: No audio player support for: pulse
 spotify  [2021-06-29T17:10:02Z INFO  librespot_playback::player] Loading <My People> with Spotify URI <spotify:track:2xpdY9XE4nR8pp92lW68Eh>
 spotify  [2021-06-29T17:10:03Z INFO  librespot_playback::player] <My People> (230373 ms) loaded
 sound-supervisor  Playback started, announcing 192.168.0.68 as multi-room master!
 multiroom-client
 multiroom-client  2021-06-29 17-10-18.211 [Error] (Snapclient) PCM device "default" not found
 multiroom-client  2021-06-29 17-10-18.252 [Fatal] (Snapclient) Exception: No audio player support for: pulse
 multiroom-server  2021-06-29 17-10-18.255 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
When I run Diagnostic Checks, everything except check_service_restarts reads good:
            "name": "check_service_restarts",
            "success": false,
            "status": "Some services are restarting unexpectedly: (service: /multiroom-client_3747072_1839466 restart count: 46) (service: /multiroom-server_3747071_1839466 restart count: 3) (service: /audio_3747068_1839466 restart count: 1)"
I’m also seeing this in the logs:
but I’ve set the AUDIO_OUTPUT Device Variable to RPI_HEADPHONES
Ok, let’s do two more tests. First, what happens if you set a variable for SOUND_MODE to STANDALONE?
Next, I know you said you were testing Spotify, but what about Bluetooth? Do you get any output if you connect to the device via Bluetooth, like I did on mine?
@dtischler , thanks for your reply :slight_smile:
It seems that, yes, setting the SOUND_MODE to STANDALONE does allow Spotify to play through the Spotify service on the device.
However, I’m unable to connect to the Bluetooth service permanently, as it kicks back to Disconnected almost immediately and then will not reconnect. (MacOS) Actually, while I wrote this out, Bluetooth eventually connected consistently. I’m not sure how or why it didn’t do it right away.
As soon as I remove the STANDALONE variable from the sound mode, though, the sound again goes mute. So, I can get one device to work at a time, perhaps? But not multi-room, it seems. That may be a limitation of Spotify that I’m unaware of. Is that the case? Spotify Premium, for what it’s worth.
My second device is hanging on “VPN Only”, I assume that issue is out of scope for this discussion, so perhaps I’ll open another forum thread if I can’t resolve that through research.
Thanks for the help so far! I really appreciate it.
To summarize:
  • Running 32-bit balenaOS on RPi 3 B+ will work!
  • Setting AUDIO_MODE to STANDALONE does appear to allow sound through a single device.
  • Bluetooth is unpredictable, but is working as of this writing
  • Spotify Premium works with the Spotify Connect remote player (Icon is speaker in a circle) from the Spotify client on desktop / mobile
  • I’m trying to get multiroom working with multiple RPi 3B+ with the same release mode, which STANDALONE seems to prevent (multiroom-server and multiroom-client services are stopped)
  • Airplay does not appear to be working, unless I misunderstand the relationship between Spotify Connect and Airplay
Any tips on getting multiroom working with my hardware configuration? Do I need to bite the bullet and order a few RPi 4s?
Thanks so much!
Thanks for getting back and great summary. I see we had some issues with multiroom setup back in Mar’ and then some more updates more recently. Can you help us understand two things:
  • How you deployed balenaSound i.e. what route ?
  • What commit or version of balenaSound are you running (hoping greater than v3.5.2+)?
RaspberryPi 3 B+ is one of the [recommended device] (Getting started - Home), so you’d not need an upgrade to get balenaSound to work. Having said that the above two can help us see if there is something with a version which is currently running.
Cheers,
N
Thank you for checking in on this @nitish .
The deployment route was to use Balena Etcher to flash microSD card with the selected Production version of the 32-bit RPi 3-supported OS, then deploy via the “Deploy with balena” button on the sound.balenalabs.io page.
The balenaSound version is 3.6.5 / commit b8f7eaf
The Source value is cloud, which I believe is informed by the deployment method, but I’m new to this infrastructure so I don’t know if that’s true.
Let me know if I’ve reported everything accurately - I think I have - and if there’s a more reliable or stable deployment method.
Thanks again!
Hi Jon, thanks for the diagnostic feedback you’ve already provided. It looks to me like there is a problem with the audio block which is causing the snapcast server to be unable to start and thus the snapcast client. From the logs you posted:
I am not exactly sure why no one else would be having this error though. I will ping the creator and see if he has any ideas.
Actually, scratch that, can you try re-deploying balena sound? it looks like there was a bug that was fixed that might be related. It might not be the problem, but worth a try.
You can redeploy with the “Deploy With Balena” button here
@zwhitchcox , good call. I upgraded to 3.6.8 and I am able to run sound out of the 3.5mm output jack directly from the RPi, with multiroom-server and multiroom-client enabled (removing the AUDIO_MODE=STANDALONE from the device variables). I’m not sure how to enable the multiroom playback, but that’s something I can research on my own. Thanks, all, for your patience and assistance.
