Newbie Question regarding installing some Grafana plugins / telegraf agent
Hi !
I made the tutorial “Take readings from a BME680 sensor or Sense-HAT on a Pi or Pi Zero, store with InfluxDB and view with Grafana” and I would like to add some grafana plugins and a Telegraf agent. Is this possible or I should make it all from scratch ? I tried to make some post instalation through the terminals (grafana terminal) but it did not worked. Thanks in advance.
Regards,
Hi @osokaru, welcome to balena! I’m not an expert on grafana, but I would imagine you could add the plugins to the Dockerfile here: https://github.com/balena-io-projects/balena-sense/blob/master/grafana/Dockerfile.template . You could also add the telegraf service in there too or you could add it as another container as in this example project https://github.com/balena-io-playground/multicontainer-metrics/tree/master/metrics that sets up the full T.I.C.K stack
Thx. First, I need to learn a little bit about Docker then I’ll try it. Balena its an excellent platform for learning some DevOps technologies. I will play a lot with it. Regards from barcelona!
:relaxed:
