New error in balena etcher
Hello, this just means that the data read from the drive after flash is not exactly the same as the one in the image.
This can have 2 meanings:
  • the flash drive has broken sectors that do not write what they are asked to;
  • something writes data on the drive in the moment between Etcher finishes writing and the moment Etcher finishes verifying.
As this image contains a fat32 partition (the second one) and you’re using Windows, it may be Windows creating a System Volume Information folder on that partition.
If that’s the case, you can use the drive normally, it should boot fine.
Check https://superuser.com/questions/1199823/how-to-prevent-creation-of-system-volume-information-folder-in-windows-10-for for ways of preventing Windows from doing that.
