Hey, Guys
I encountered a new problem when trying to flash linux mint 20 xfce into the sd card
here are the screenshots
please solve the query
thanks
Hey, Guys
thanks
Hello, this just means that the data read from the drive after flash is not exactly the same as the one in the image.
This can have 2 meanings:
As this image contains a fat32 partition (the second one) and you’re using Windows, it may be Windows creating a System Volume Information folder on that partition.
If that’s the case, you can use the drive normally, it should boot fine.
Check https://superuser.com/questions/1199823/how-to-prevent-creation-of-system-volume-information-folder-in-windows-10-for for ways of preventing Windows from doing that.
thanks
