We encountered an error when reaching this balena.io device:
UUID xxxx
tunneling socket could not be established: 500
One possible reason is because nothing is listening on port 80 on the device.
What does this mean? What ports need be forwarded?
UUID xxxx
OK, following this arcticle:
When I try to open public url, I get the fail message described above.
I assume some ports I need open on my router are not?
Thank you,
Is there anything suspicious in the logs? You can also use the terminal, log into the host and run balena ps to check which containers are running
18.09.20 14:01:36 (-0600) Supervisor starting
18.09.20 14:01:37 (-0600) Applying configuration change {“SUPERVISOR_POLL_INTERVAL”:“900000”,“SUPERVISOR_DELTA_VERSION”:“3”}
18.09.20 14:01:37 (-0600) Applied configuration change {“SUPERVISOR_POLL_INTERVAL”:“900000”,“SUPERVISOR_DELTA_VERSION”:“3”}
18.09.20 14:01:37 (-0600) Creating network ‘default’
18.09.20 14:01:37 (-0600) Applying configuration change {“SUPERVISOR_DELTA”:“1”}
18.09.20 14:01:37 (-0600) Applied configuration change {“SUPERVISOR_DELTA”:“1”}
03.09.20 14:58:33 (-0600) Supervisor starting
19.09.20 15:32:11 (-0600) Supervisor starting
