I get the error tunneling socket could not be established: 500 on my raspberry pi and cant seem to connect to it
Hey @Ryan welcome to the forums.
We’ll need a little more information to be able to help here - could you describe the steps you’re taking to reach this message, and perhaps some information about your use case and what you’re trying to build?
I got the same error this time and used the steps described in the following tutorial for the raspberry-pi senor project with Grafana:
https://blog.balena.io/build-an-environment-and-air-quality-monitor-with-raspberry-pi/
Is there a quick workaround or fix for this issue?
We encountered an error when reaching this balena.io device:
UUID 35XXXXXXXXXXXXXXXXX
One possible reason is because nothing is listening on port 80 on the device.
Hello @katsumoto84 when do you see this message?
Are you using the Public Device URL? Communicate outside the container - Balena Documentation
