My usb wont show.
I just got balenaetcher and my USB won’t show I’m on chrome os.
Welcome to the balena forums @sprejo,
Could you please provide some more information on this?
I guess balena etcher version and your os version should make a good start here.
Maybe check if your system can access the USB-stick as well.
Regards Markus
Hi @sprejo
do you still face the issue?
If yes can you detail as asked earlier?
  • your OS version
  • the etcher version you use
in addition clarify your problem. Is it like
  • you start etcher and your pendrive plugged to an USB port is not visible in etcher (selecting as a target) or
  • you flash the usb stick with etcher then you plug it to your chromeOS computer and the device does not show up in the file manager?
Peter
@sprejo did you solve your issue?
Looking forward to see the answers of my colleague’s questions.
