Modify wifi configuration on BalenaOs with Screenly
Hi there!
I didn’t find a simple way to modify wifi configuration and connect my device without ethernet.
The initial configuration works find when I made SD card by creating an app with BalenaCloud wizard. 1/ copy .img file to SD card with Etcher 2/ put it in my Rpi 4 device 3/ start it and system connect to the internet well
Unfortunately, I moved my device to another place and SSID / pwd is different indeed.
How I can find a way to modify initial wifi setup with online terminal Balena.io?
Can I use VI or nano for example to change a configuration Raspbian boot files or somewhere else?
Do you think is something it’s possible to add in services variables than could take effect after rebooting device? (or kind-of?!)
Thank you for your answer!
If you have physical access to the SD-card. You can edit system-connections/balena-wifi-01 with your new wifi credentials. Using WiFi-connect as a service can also help if you set it up on your devices.
Hi @iamsolankiamit,
Thanx for your prompt and very good answer!
As I have the capability to access to the SD card but didn’t have Linux OS right by my side…
  • Nevermind - I installed VM VirtualBox with Ubuntu 20.04 as main-test-LinuxOS, mount Gerenic SD card reader available in my ROG g752 (running on W10home), swap SD card from myRpi and I saw everything I ever saw since I mount the card by Etcher (Balena wizard to get Screenly on Pi).
4 partitions :
  • resin-boot
  • resin-data
  • resin-rootA
  • resin-rootB
I had the happiness to see files and directories (yes, i’m getting older and i’m pretty old, I’m defenetly a directories-man! :slight_smile: )
It was easy to edit system-connections/balena-wifi-01 (so simple, so ridiculous to me… I can say “shame on me!!!”)
Hope this sharing is helpful for the community
Thanx again @iamsolankiamit !!
