I am following this tutorial to install balena network camera in Raspberry Pi 4B 4GB.
I have installed the balena cli in my Ubuntu 18.04 machine. After i loged in and try to push the apps with balena command
balena push myapp
I’m getting this error:
[Warn] “docker-compose.y[a]ml” file found in parent directory: please check
[Warn] that the correct folder was specified. (Suppress with ‘–noparent-check’.)
[Info] Starting build for myPi, user gh_roboticsai
[Info] Dashboard link: balena dashboard
[Info] Building on arm03
[Info] Pulling previous images for caching purposes…
[main] Step 1/9 : FROM balenalib/raspberrypi4-64-debian:stretch-20190612
[main] manifest for balenalib/raspberrypi4-64-debian:stretch-20190612 not found
[Error] Service: main
[Error] Error: manifest for balenalib/raspberrypi4-64-debian:stretch-20190612 not found
[Info] Built on arm03
Remote build failed
variable: "set DEBUG=1" on a Windows command prompt, "$env:DEBUG = 1" on
powershell, or "export DEBUG=1" on Linux or macOS.
https://forums.balena.io
For CLI bug reports or feature requests, have a look at the GitHub issues or
How do i solve this problem. I am working in small project for which the network camera + audio is very important and URGENT.
