Pushing the project code to your Raspberry Pi Impossible
Hello.
I’m stucked at this stage …
I get this log :
 C:\balena-cli>balena push balenaDash
[Info]     Starting build for balenaDash, user gh_touchthebitum
[Info]     Dashboard link: https://dashboard.balena-cloud.com/apps/1345780/devices
[Info]     Building on arm01
[Info]     Pulling previous images for caching purposes...
[Success]  Successfully pulled cache images
[Error]    Some services failed to build:
[Error]      Service: main
[Error]        Error: Cannot locate specified Dockerfile: Dockerfile
[Error]    Not deploying release.
Remote build failed
If you need help, don't hesitate in contacting us at:
  GitHub: https://github.com/balena-io/balena-cli/issues/new
  Forums: https://forums.balena.io
Help
Hi there, are you executing the command within the root folder of the repository? the error means that balena-cli could not find a Dockerfile in the current directory
I’m executing from c:/balena-cli
you need to execute that command from the repository that is created when you did git pull from github ( here https://www.balena.io/blog/make-a-web-frame-with-raspberry-pi-in-30-minutes#downloadingthebalenadashprojectfromgithub )
sorry, I meant to write: from the folder that was created when you did git pull from github
in your link it says do download or git clone , but where do I type git clone https://github.com/balena-io-projects/balena-dash.git ?
I’m lost
ok , it worked
Hi just to make sure, have you managed to deploy the application in the end? Cheers!
yes, Ithink. I have Youtube login page on the screen but I don’t see where I can cancel it to build a new dashboard
Would the section in the blogpost, called Displaying Your Own Content what you are looking for?
ok but I’m trying to insert a webpage and I always get youtube page
Hey @touchthebitum, did you add the **Device Variable**WPE_URL` where the value would be the URL you are trying to display?
Cheers
