I have my RPI4 set up on BalenaCloud. Control with both Spotify and AirPlay works great. My only issue is that the output volume seems very low. I have the RPI connected to a large Control4 amp with lots of power. Other input devices do not need to be turned up all the way but this one does and is still pretty anemic. Can I modify the output sound level of the Pi using the dashboard? Are there other possible solutions?
Hi, could you take a look on this other thread and see if it helps with your issue: Balena sound low output
Hello, just following up to see if you were able to resolve the low output volume on your RPI?
I think it is good now. I was able to edit the sounds configuration with my PC.
Good, don’t hesitate to contact us if you have further questions…
