I’ve been working through some changes for my github project. However I’m struggling to get my changes tested locally.
I’ve made my changes on branch:develop & although it’s checked out & active. When I run balena push -s . 192.168.1.5 from within my source directory I get the old version without my changes running on my Pi
What should I be doing here to test my changes locally before deploying?
Right, I’ve spent 2 evenings trying to get this working. As far as I can tell balena push is not building my local version
I’ve tried
• Logging into device, running various docker commands balena system prune, removing the old containers
• Different image (PiHole) as this does seem to load PiHole
• Changing balena yml (name + url)
Regardless however when triggering balena push I still keep getting the old images:
root@9e3da5b:~# balena ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
dc6b39561434 1f112809d961 "./start.sh" 17 minutes ago Up 17 minutes fbcp_3_1
2afadc957f3d d2e032d4a69a "/docker-entrypoint.…" 17 minutes ago Up 17 minutes 0.0.0.0:80->80/tcp netspeed_1_1
01642bdf46fc fa7ca3bc2ac4 "bash start.sh 'expo…" 17 minutes ago Up 9 seconds browser_2_1
52497eeb30c0 registry2.balena-cloud.com/v2/3a9066ce744bf2ed13c472c8e827c924:latest "/usr/src/app/entry.…" About an hour ago Up 25 minutes (healthy) resin_supervisor
See above, netspeed_1_1, is running image from registry2.balena-cloud.com/v2/3a9066ce744bf2ed13c472c8e827c924:latest, when it should be running the local version
Hi @ryandev, I’m not sure I follow you. The console output you shared is saying that resin_supervisor container which is our on device supervisor is running registry2.balena-cloud.com/v2/3a9066ce744bf2ed13c472c8e827c924:latest.
You can inspect balena image ls to see what the image source for those containers is, and wether they are built locally or served via our cloud.
Here is sample output from one of my devices in local mode, as you can see images built locally using local mode/livepush are prefixed with local_:
root@balena-9:~# balena ps
d701e1aa4061 a856e6c10d42 "/usr/bin/entry.sh /…" 5 days ago Up 5 minutes avahi_3_1
9540a8d8736e dad90866d171 "/docker-entrypoint.…" 5 days ago Up 5 minutes 0.0.0.0:8080->80/tcp webservercopy_2_1
a1660d15bdf5 dad90866d171 "/docker-entrypoint.…" 5 days ago Up 5 minutes 0.0.0.0:80->80/tcp webserver_1_1
45caa2d547c8 registry2.balena-cloud.com/v2/3a9066ce744bf2ed13c472c8e827c924:latest "/usr/src/app/entry.…" 5 days ago Up 16 seconds (health: starting) resin_supervisor
root@balena-9:~# balena image ls
REPOSITORY TAG IMAGE ID CREATED SIZE
local_image_avahi latest a856e6c10d42 5 days ago 83.5MB
<none> <none> a520ced6e02c 5 days ago 83.5MB
<none> <none> 5fe8c360a5c2 5 days ago 83.6MB
<none> <none> 9dc9096b293f 5 days ago 83.6MB
<none> <none> 72cee2e901a5 5 days ago 209MB
<none> <none> f0479f32b9bf 5 days ago 209MB
<none> <none> a74e1e6a0d38 5 days ago 209MB
<none> <none> bc054eff80d8 5 days ago 164MB
<none> <none> 38495a2c13e3 5 days ago 164MB
registry2.balena-cloud.com/v2/24d227324e4d9eef1d9eb3df75db1008 <none> d1d4918925e4 12 days ago 176MB
balenalib/raspberrypi4-64-debian latest 3f6358dfa109 13 days ago 164MB
balenalib/raspberrypi4-64-alpine latest e54669187df1 13 days ago 83.5MB
registry2.balena-cloud.com/v2/3a9066ce744bf2ed13c472c8e827c924 latest 7505b0572456 4 weeks ago 72.5MB
balena/aarch64-supervisor v12.5.10 7505b0572456 4 weeks ago 72.5MB
local_image_webserver latest dad90866d171 2 months ago 21.2MB
local_image_webservercopy latest dad90866d171 2 months ago 21.2MB
balena-healthcheck-image latest a29f45ccde2a 16 months ago 9.14kB
Hey @ryandev, Let us know if you’re still having problems with this.
