Could not communicate with local mode device at address 10.168.50.81
I’ve checked that I’m running a development variant of the OS, local mode is enabled on the device, the ip address is from sudo balena local scan. The only requirement missing is I’m using ResinOS 2.14.0+rev4 because that is all that is supported by the CTI Orbitty TX2 devices.
Are there any other things or logs I can check? I can ssh into the device, but that uses the uuid not the ip address.
Hi ! I think this might be it - the local mode needs a newer version of the OS - we can let you know when there is a new OS version available for that device. I can see we have 2.31.2+rev1 in our tetsting for that device right now.
Hey @jason10 we have now released 2.31.5+rev1 version of the OS on the CTI Orbitty TX2 board. I believe this should fix the issues you were experiencing with localMode pushes.
@pdcastro I work with @jason10 and I am attempting to get local mode to work with a CTI Orbitty TX2 board.
I reflashed my Orbitty/TX2 with 2.31.5+Rev 1 (development).
I enabled local mode in the dashboard.
When I execute the command “balena push 192.168.0.28” it builds and deploys, but when it tries to start I get the error message “./hw_mon: cannot execute binary file: Exec format error”, exit code 126.
unfortunately the balenaOS version available for the IOT2000 device is still at 2.12.7+rev2
Node.js no longer supports the CPU architecture for the device which will require us to maintain a fork of the supervisor and OS to keep it updated for the right architecture. We are currently assessing some options and also the ROI for the engineering work required to maintain this device type given the very few devices of this type we have on the platform
