Local balena push command does not to work
Hi there
Started playing around with balena and checkin gout local development. However I ran into a problem with local deployment.
Command sudo balena scan does show me my device as expeced running balenaOS 2.38.0+rev1. I can also access the device via balena ssh <device-ip>. So far so good.
As soon as I try a balena push <device-ip> it fails due to:
Could not communicate with local mode device at address
Switchin DEBUG on it seems that communication with port 48484 does not work:
[Debug]   Checking we can access device
[Debug]   Sending request to http://<device-ip>:48484/ping
Pushing the project using the balenaCloud does work.
I’m using balena-cli v11.9.3.
Any idea what might be wrong?
Many thanks!
Have you enabled Local Mode via the Dashboard? Check out the list of requirements here: https://www.balena.io/docs/learn/develop/local-mode/#local-mode-requirements
Shame on my reading skills… over read the last but most important point:
Local mode must be enabled through the dashboard. To use local mode on a development device, click on the small Actions dropdown at the top right of the device page and select Enable Local Mode .
Somehow I expected to have the local mode automatically enabled when using the image with development mode enabled.
Hey @klatr,
Just to let you know, we have an open issue (https://github.com/balena-io/balena-cli/issues/1304) to allow people to enable local mode from the CLI itself, which may help you in the future.
I do think the docs on this point could be clearer.
Develop locally - Balena Documentation says
Local mode is the development mode for balena.
Which suggests that ā€˜local mode’ and ā€˜development mode’ are synonyms.
It looks like this feature has now been released, so you can enable local mode for your device from the CLI starting from v12.39.0.
