Reference this project: balena-io-examples/internetspeedtest,
It’s clearly an older project but a great example to start out with and deploy across site to check for speed issues etc. Unfortunately the speedtest doesnt actually run, citing the below error:
ImportError: cannot import name 'Literal' from 'typing' (/usr/local/lib/python3.7/typing.py)
speedtest
speedtest During handling of the above exception, another exception occurred:
speedtest
speedtest Traceback (most recent call last):
speedtest File "./speedtest.py", line 5, in <module>
speedtest import paho.mqtt.client as mqtt
speedtest File "/usr/local/lib/python3.7/site-packages/paho/mqtt/client.py", line 51, in <module>
speedtest from typing_extensions import Literal # type: ignore
speedtest ModuleNotFoundError: No module named 'typing_extensions'
Just starting out with Balena Cloud etc and so no doubt I will use this project as a basis to building my own version but if anyone has any quick tips on getting this up and running its appreciated. Thanks
