Installing BalenaSound with Hoobs
Hi Guys,
First of all I don’t have a lot of experience with Docker, so perhaps my issue is fairly simple. Yet, I did not find anyone online with a solution.
MAIN GOAL
I want to run on my raspberry pi BalenaSound(for now 1 device), and Hoobs(Homebridge Out Of the Box). I tried with homebridge as well but without success.
I can install correctly and working the BalenaSound, but it seams Hoobs is stuck on start saying : “Installing service 'hoobs sha256XXXXXX”
The main questions are : Is my docker-compose ok? will this be enought to download the image and install it?
Do I need a start.sh file ? if so how do i know it is running?
version: ‘2’
volumes:
spotifycache:
hoobscache:
services:
audio:
build: ./core/audio
privileged: true
labels:
io.balena.features.dbus: 1
ports:
- 4317:4317
sound-supervisor:
build: ./core/sound-supervisor
network_mode: host
ports:
- 3000:3000
labels:
io.balena.features.supervisor-api: 1
multiroom-server:
build: ./core/multiroom/server
restart: on-failure
ports:
- 1704:1704
- 1705:1705
- 1780:1780
multiroom-client:
build: ./core/multiroom/client
restart: on-failure
bluetooth:
build: ./plugins/bluetooth
restart: on-failure
network_mode: host
cap_add:
- NET_ADMIN
labels:
airplay:
build: ./plugins/airplay
restart: on-failure
network_mode: host
privileged: true
labels:
spotify:
build: ./plugins/spotify
restart: on-failure
privileged: true
network_mode: host
volumes:
- spotifycache:/var/cache/raspotify
upnp:
build: ./plugins/upnp
restart: on-failure
network_mode: host
ports:
- 49494:49494
hoobs:
image: hoobs/hoobs
container_name: hoobs
environment:
- PUID=1001
- PGID=1001
- TZ=Europe/Amsterdam
volumes:
- hoobscache:/opt/appdata/hoobs:/hoobs
ports:
- 8080:8080
- 8181:8181
- 51826:51826
restart: always
Thanks guys.
Hi there, are you following this tutorial? https://www.balena.io/blog/two-projects-one-device-turn-your-raspberry-pi-into-a-multitool
I don’t see anything specifically wrong with you compose file. Though it might be good to check if HOOBS runs on it’s own before merging the compose files.
Also these docs explain a bit more on how to merge two projects: https://www.balena.io/docs/learn/develop/multicontainer/#docker-composeyml-file
Hi StefJKors,
I left only the hoobs part of the docker-compose and I get the same error: installing service 'hoobs sha256:XXXX…"
Is there a way to debbug why the container is not installing the image or get any other information about the issue?
At this moment I only have HOOBS on my docker-compose and I get the same error.
EDIT: I Followed that tutorial.
Hey there,
Am I right you are using a Pi4? If so:
Can you update your docker-compose to point to the Pi4 specific docker image for hoobs and try again? It should look like this (also not the change to the volumes line):
    hoobs:
        image: hoobs/hoobs@sha256:85f90f0e6eb6ae2284922bc58db55c1b2deb53e92b4b76c0c350afbe2fe4109f
        environment:
          - PUID=1001
          - PGID=1001
        volumes:
        ports:
          - 8080:8080
          - 8181:8181
          - 51826:51826
        restart: always
Phil
Thanks phill, I have tried that but i get the same error.
Hey again - did you use my snippet of docker-compose ? I have that exact thing running on a Pi4 now, with no problems.
Hi phil,
Thanks for the snippet, I tried again an it is running hoobs. Although balena is saying it is running on port 80 but i cant seem to find it. Where is it running? R
Regards
Have you tried checking for Hoobs running on port 8080?
Hi Markcorbinuk,
I tried but is not there too
Please could you post a copy of your updated docker compose file - thanks.
version: ‘2’
volumes:
hoobscache:
services:
hoobs:
environment:
- PUID=1001
- PGID=1001
volumes:
ports:
- 8080:8080
- 8181:8181
- 51826:51826
restart: always
I’ve run some tests with your docker compose file…
Hoobs is listening on internal container port 80, so you need to change the ports line to - nnnn:80 where nnnn is an external port that’s not being used by another container, e.g. - 80:80 or - 8080:80 etc.
Regards
Mark
Thank you so much! Now it is working on port 80 with nnn= 80
Regards
