install Etcher to logical drive
I have a mining rig with Windows 10 on an M2 SSD drive. I have divided that drive into 2 logical drives, C: and E: using the windows drive management interface. I wish to install HiveOS to Drive E. I expect I can then go into Bios and set Drive E as the boot drive. This preserves my Windows installation, should I need it later. When I run Balena Etcher, I am prompted to select the Hive OS source file, which is in the root of C:. I am then prompted to select the target drive, which Balena Etcher identifies as Drive C: E:. It further warns me that this is a system drive, and that installation will wipe the entire drive. There does not appear to be a way to tell Balena etcher that I want to install to Drive E, NOT Drive C.
How can I proceed to get a HiveOS image onto Drive E?
Thanks - Charlie
Hello @charliew
Writing to a specific partition is currently out of scope for etcher. There’s been a discussion here in case you’re interested.
Cheers,
Nico.
