Image written with Etcher fails to install
So, the thing is I’ve created boot image of Manjaro on a 4GB hp flash drive. And tried to install it on my system, but the image failed to install. The same image when written with Rufus worked without any issue.
OS Balena was run on to create image: Manjaro 20
HP v240 flash drive 4gb
Hi, can you tell me how you’re installing Etcher and which version you are using?
Are you sure this is the same image you are flashing with Rufus as with Manjaro?
