Hi there,
I am using a spare USB camera device connect with the raspberry follow the article here https://www.balena.io/blog/build-a-raspberry-pi-based-network-camera/.
Logs when device start https://gist.github.com/phamkythanh/b5d5eb53f50d6e0a5d9fcd8dbc93f9e3
But when I enabled public URL, the video does not render. It just keep loading like this. Do you have any idea?
Hey there
It seems like you are hitting the issue where your local IP address is hidden. Can you please confirm which browser you are using? You will find the supported browsers here
Also note that you might need to enable additional settings as mentioned here.
Cheers
Thanks for your quick reply. I am trying on Safari, my public URL https://d3795ce894255c9326d4cde92ae92850.balena-devices.com.
I also grant support access to my device https://dashboard.balena-cloud.com/apps/1758518/actions. Can you help investigate more?
hello, it seems like the device is offline? can you please check?
ah sorry, I switch it off for testing other thing. Turned on again. Can you try remote again now?
hey there, It seems to be working with chrome. Can you please try with the chrome browser?
I had to
- enable
chrome://flags/#temporary-unexpire-flags-m85
- disable
chrome://flags/#enable-webrtc-hide-local-ips-with-mdns
Thank you, its now working on my Firefox.
One more question, do you know how to put the streaming working with this Ant Media Server? The Stream URL does not recognized my Public URL https://d3795ce894255c9326d4cde92ae92850.balena-devices.com/
Hi there, what do you mean when you say it is not recognised? Is there an error message that appears?
Hi there, sorry for late reply. There is no error message display at all.
Below are the format that Ant Media support for restreaming, do you know if we can get the supported URL from balena public URL?
Ant Media Server can operate with different streaming flows. As well as accepting and creating streaming media, it also has the capability to pull live streams from external sources. Such as; live TV streams, IP camera streams or other forms of live streams(RTSP, HLS, TS, FLV etc.). We will show how to pull live streams with Web Interface.
Hey there,
As the balenaCam project stands, I do not believe you will be able to stream the feed directly. What is served on the public url is a webpage that is streaming the feed.
I have created an issue to track this . If you go about trying to implement this yourself, PRs are always welcomed
hope this is helpful
