I somehow ended up with 2 applications that perform the same thing. It is getting confusing, how can I delete one of them? Neither have any devices.
Hi, you can delete apps from the Actions tab that’s on the left side menu once you are on the app dashboard. Let me know if you need further assistance!
Thank you, I was confused because there is also an actions menu on the right side.
No problem! Yeah the one on the right is to apply actions to whatever devices you select from the devices list (which you won’t have any since the application is fresh). Have a good day!
I had the same issue earlier - go into the app itself and scroll down on the left and use the Action tab there. The delete is the final (nuclear) option.
