Help - Not getting sound from the 3.5mm jack on a Anthias Install RP3b.. its obvi a basic mistake !!
done this Analog (3.5mm Jack) not working on fresh install
and this No sound from 3.5 mm output
but this is all about BalenaSound
was thinking that the “sound” issue was a common thing, obvi not.
I’ve tried to get in the host to take a look at the config.txt but can only cat the last few lines not the total. on taking a look at what I could see it seems the config I set in the devices settings doesn’t seem to take effect.
Im obviously not setting it correctly.
Any help or pointers would be appreciated.
D
I can help you troubleshoot the 3.5mm jack issue on your Anthias Install RP3b. Here are some steps based on the information you provided and common causes:
1. Check Hardware:
  • Basic Checks: Ensure the cable is firmly plugged into both the Raspberry Pi and your speakers/headphones. Try a different cable to rule out cable issues. Make sure your speakers or headphones are powered on and functioning correctly.
  • Visual Inspection: Look for any physical damage to the 3.5mm jack on the Raspberry Pi or the cable connector.
2. Software Configuration:
  • Verify Audio Settings: Access the Raspberry Pi configuration using sudo raspi-config (assuming you have root access). Navigate to “System Options” → “Audio” and ensure the correct audio output is selected (likely “Analog” for the 3.5mm jack).
  • Check config.txt (if possible): While you mentioned limited access, if you can view or edit the complete config.txt file, look for lines related to audio output. These might include dtparam=audio=on or dtoverlay=i2s-wm8804 . Uncomment these lines or adjust them as needed based on your Raspberry Pi model and sound card. However, proceed with caution and research specific settings for your Anthias Install RP3b configuration.
3. Additional Troubleshooting:
  • Reboot: Sometimes a simple reboot can resolve configuration issues. Run sudo reboot to restart your Raspberry Pi.
  • Force Audio Output (if applicable): Some advanced users might suggest forcing audio output to the 3.5mm jack using commands like amixer sset "Auto Mute" unmute or amixer sset "Headphone" on . However, this depends on your specific system and might require more research to ensure compatibility with your Anthias Install RP3b.
  • Consult Anthias Documentation: If available, refer to the Anthias Install RP3b documentation for any specific audio configuration instructions or known limitations.
Things to Avoid:
  • Modifying Unknown Settings: Avoid modifying settings in config.txt or other configuration files unless you understand their purpose and potential consequences. This could lead to further issues.
Additional Tips:
  • Community Support: Consider searching online forums or communities dedicated to Raspberry Pi and/or Anthias Install for solutions specific to your setup.
  • Professional Help: If you’re uncomfortable with the troubleshooting steps or the problem persists, consider seeking assistance from someone with Raspberry Pi experience.
By following these steps and considering potential causes, you should be able to diagnose and fix the issue with the 3.5mm jack on your Anthias Install RP3b. Remember to prioritize hardware checks and verify software configuration options cautiously before making advanced modifications.
@nicomiguelino could you please help here?
Seems to be os related as ive tried to connect to bluetooth speakers and they also don’t work. got this from a host os terminal
[bluetooth]# connect FC:58:FA:60:69:7C
Attempting to connect to FC:58:FA:60:69:7C
Failed to connect: org.bluez.Error.Failed br-connection-profile-unavailable
On a plus side I did get audio from a HDMI tv through the HDMI channel so sound is actually being generated but no sound on the 3.5 jack or bluetooth outputs.
bit of a pain :frowning:
D
ps is AVA a bot ?
"vc4-fkms-v3d","ads7846","cs=1","penirq=25","speed=50000","keep_vref_on=0","swapxy=0","pmax=255","xohms=150","xmin=200","xmax=3900","ymin=200","ymax=3900"
this is in the config file for a 5" screen on the pi that has the error with the 3.5mm jack
D
this is in the one above
"audio=on","i2c_arm=on","spi=on","audio_output=Headphones”
@DeanoThePlumb could you please confirm what device and OS version are you using?
and BTW welcome to the balena community!
@DeanoThePlumb, I checked if the audio (via 3.5mm) works in my Pi 3B+ by doing the following:
  • Open a browser and go to http://<anthias_ip_address>/settings.
  • From the Audio output dropdown, select 3.5mm jack.
  • Upload a video asset.
I’m getting sound from my Pi (for both Balena and Raspberry Pi OS Lite). If you’ve done the steps that I mentioned above and didn’t work, please provide the following details:
  • the OS the Pi is running on
  • your /boot/config.txt or /boot/firmware/config.txt
I feel such a plonker…
I didn’t “try all the buttons” as I normally do as. I was convinced it was another “more complex” issue at fault.
Many thanks for the help
Deano
I did update the os to the latest at the time but the solution below was the fix as I didn’t even see the dropdown (lol)
