"Got 401 when requesting image from delta server" error
Hello :slight_smile:
I have some problem to update my raspberry pi3.
from yesterday, It seems like my raspberry p3 can’t download delta from your registry server.
here’s an error message :
27.03.18 18:13:44 (+0900) Downloading delta for application ‘registry2.resin.io/v2/xxxxxxxxxxx’
27.03.18 18:20:18 (+0900) Failed to download application ‘registry2.resin.io/v2/xxxxxxxxxxx’ due to ‘Got 401 when requesting image from delta server.’
27.03.18 18:20:26 (+0900) Downloading delta for application ‘registry2.resin.io/v2/xxxxxxxxxxx’
I’ve restarted my device but nothing changed :frowning:
Is there any solution for this?
please let me know if you need more info.
thanks for your help.
Hello, we’re aware of the issue and expect to have a fix in production later today or tomorrow. In the meantime you can work around this by disabling deltas.
thanks :slight_smile:
