I had a resin.io project which worked fine. If I now try to push the project I have git issues. Any suggestions?
[Info] Dashboard link: https://dashboard.balena-cloud.com/apps/1298225/devices
[Info] Building on arm02
[Info] Pulling previous images for caching purposes...
[main] Step 1/9 : FROM resin/raspberrypi3-node:6-slim
[main] ---> 7fe2e8c1402b
[main] Step 2/9 : RUN apt-get update && apt-get install -yq git python2.7 bluetooth bluez libbluetooth-dev libudev-dev bluez-firmware && ln -s /usr/bin/python2.7 /usr/bin/python && apt-get install build-essential curl && apt-get install -y dnsmasq wireless-tools && apt-get clean && rm -rf /var/lib/apt/lists/*
[main] Using cache
[main] ---> c13518b3f978
[main] Step 3/9 : WORKDIR /usr/src/app
[main] Using cache
[main] ---> afdbeeab0c6b
[main] Step 4/9 : RUN curl https://api.github.com/repos/resin-io/resin-wifi-connect/releases/latest -s | grep -hoP 'browser_download_url": "\K.*armv7hf\.tar\.gz' | xargs -n1 curl -Ls | tar -xvz -C /usr/src/app/
[main] ---> Running in b307836edf2c
[main] curl: no URL specified!
[main] curl: try 'curl --help' or 'curl --manual' for more information
[main]
[main]
[main] gzip: stdin: unexpected end of file
[main]
[main] tar: Child returned status 1
[main] tar: Error is not recoverable: exiting now
[main]
[main] Removing intermediate container b307836edf2c
[main] The command '/bin/sh -c curl https://api.github.com/repos/resin-io/resin-wifi-connect/releases/latest -s | grep -hoP 'browser_download_url": "\K.*armv7hf\.tar\.gz' | xargs -n1 curl -Ls | tar -xvz -C /usr/src/app/' returned a non-zero code: 2
[Info] Uploading images
[Error] Service: main
[Error] Error: The command '/bin/sh -c curl https://api.github.com/repos/resin-io/resin-wifi-connect/releases/latest -s | grep -hoP 'browser_download_url": "\K.*armv7hf\.tar\.gz' | xargs -n1 curl -Ls | tar -xvz -C /usr/src/app/' returned a non-zero code: 2
To git.balena-cloud.com:bogerssande_r/tcy-fleet1.git
! [remote rejected] master -> master (hook declined)
error: failed to push some refs to `
