Hi.
Me an my team are getting the following error when trying to push to resin via git.
[Info] Building on arm03
[Info] Pulling previous images for caching purposes…
[Error] There was an error setting up the build secrets for this build
[Error] No error information available
[Error] Please check your configuration matches your secret directory
This happens on different boards and all users, and we have confirmed there have not been any changes to the configuration recently. We started seeing this error recently, more specifically after the resin service outage on Aug 1, 2018. Can you please help us figure a solution for this? Let me know if there’s more information I should provide.
An example of an affected resin board is balena dashboard
