I’ve quickly tried the latest version under Ubuntu, and all seems to be working correctly. As it looks as if it’s failing in the phase where it tries to install easyrsa, there’s potentially a couple of reasons this might go wrong:
The shell being used to execute the setup scripts isn’t supported (for example if you’re trying to run this in a Windows 10 shell)
It’s possible that the attempt to fetch the easyrsa release has failed, and no data is being passed to the underlying tar command that then fails. Does your network have any filtering or firewalls on it which might be blocking the ability for this package to be downloaded?
Yes, Its ubuntu 16.04 version. yes Its office machine and there might be some firewall exceptions. But How do I resolve this? Will I need any firewall exemption?? If Yes then which can you please let me know for the same.
If this is not installed, then it will attempt to fetch a specific release from that Github repository and install it before continuing. The error you’re seeing suggests that it can’t fetch the release, which I suspect means your firewall is blocking access to Github (or a set of Github repos). The script in question is the scripts/ssl-common.sh shell script.
It is also worth noting that openBalena requires access to the Dockerhub registry (https://hub.docker.com/) to pull the openBalena services required to run. You should ensure that your firewall also grants access to the registry to ensure that these images can be pulled.
