i’ve been flashing Pop!_OS onto a USB tried SD cards as well (multiple). But still getting the same error: this is the console:
Sat Oct 24 2020 20:18:49 GMT+0200 (stredoeurópsky letný čas) Done ({"image":{"size":2275016704,"name":"pop-os_20.04_amd64_intel_13.iso","hasMBR":true,"partitions":[{"offset":163840,"size":4194304,"type":239,"index":1}],"extension":"iso","path":"C:\\Users\\natac\\Downloads\\pop-os_20.04_amd64_intel_13.iso"},"drives":[{"size":4043309056,"isVirtual":false,"enumerator":"USBSTOR","logicalBlockSize":512,"raw":"\\\\.\\PhysicalDrive2","error":null,"isReadOnly":false,"displayName":"\\\\.\\PhysicalDrive2","blockSize":512,"isSCSI":false,"isRemovable":true,"device":"\\\\.\\PhysicalDrive2","busVersion":"2.0","isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":null,"mountpoints":[],"description":"USB 2.0 USB Flash Drive USB Device","isUAS":false}],"driveCount":1,"uuid":"ccac4f2d-525f-457c-9403-0f0664243545","status":"finished","flashInstanceUuid":"ccac4f2d-525f-457c-9403-0f0664243545","unmountOnSuccess":true,"validateWriteOnSuccess":true,"errors":[{"name":"Error","code":"EVALIDATION","device":"\\\\.\\PhysicalDrive2"}],"devices":{"failed":1,"successful":0},"bytesWritten":2273312768,"sourceMetadata":{"size":2275016704,"name":"pop-os_20.04_amd64_intel_13.iso","blocks":[{"blocks":[{"offset":0,"length":2275016704}]}],"blockmappedSize":2275016704},"sample":0.1,"applicationSessionUuid":"8902c641-8a0c-4651-829a-ad510762c39a","flashingWorkflowUuid":"a162c2bf-1f32-4158-aaae-6418f03504b2"}) gui.js:48927 Sat Oct 24 2020 20:18:49 GMT+0200 (stredoeurópsky letný čas) SafeWebview loaded ({"event":{"id":69,"url":"https://www.balena.io/etcher/success-banner/?etcher-version=1.5.109&api-version=2&optOutAnalytics=false","method":"GET","timestamp":1603563529982.545,"resourceType":"mainFrame","ip":"68.183.215.91","fromCache":false,"statusLine":"HTTP/1.1 200","statusCode":200,"responseHeaders":{"age":["2402"],"cache-control":["public, max-age=0, must-revalidate"],"content-encoding":["br"],"content-length":["6470"],"content-type":["text/html; charset=UTF-8"],"date":["Sat, 24 Oct 2020 17:38:43 GMT"],"etag":["\"cc1b67974a88126a5010a7c4d4f7f048-ssl-df\""],"link":["</webpack-runtime-3a7449e0d17bfae6d676.js>; rel=preload; as=script, </styles-ae6d046c35c187471a06.js>; rel=preload; as=script, </framework-49543daea9f3e54ed3eb.js>; rel=preload; as=script, </73ad3401-f1b16c54c781b6334272.js>; rel=preload; as=script, </532a2f07-f8962197ebd575048aef.js>; rel=preload; as=script, </app-9d1edd04b4b9c81acffc.js>; rel=preload; as=script, </c943faba-db53744371810ee1b6a2.js>; rel=preload; as=script, </af13d906-d19bd41044e43a18d79c.js>; rel=preload; as=script, </ec1189df-cd9eecc4bce7e8eb393f.js>; rel=preload; as=script, </29107295-cc8712978f6051502705.js>; rel=preload; as=script, </a9a7754c-89160c11e5d846782e95.js>; rel=preload; as=script, </4cb05eeb-76399205f5e8cc3a6edf.js>; rel=preload; as=script, </231dbb27-68eda63ea4bd6b7d6c02.js>; rel=preload; as=script, </09701b4e-679cc6225d7a7c57508c.js>; rel=preload; as=script, </8adc965a-0a7d3c2c406e33a9f402.js>; rel=preload; as=script, </42cf64af-75df0380b6cdc8c7c1fc.js>; rel=preload; as=script, </commons-dbf4ce0d9e6b856e6f0f.js>; rel=preload; as=script, </fa5ad257d571af33d737afaa118648b294b3ca41-1483844bce6db0eb141c.js>; rel=preload; as=script, </1f9101bfa6ab6b5c77f1b7191fb4987950aee8e9-d8f1dbc3ea16a0377679.js>; rel=preload; as=script, </component---src-pages-etcher-success-banner-js-b56ea64b390fda7080fc.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin"],"referrer-policy":["same-origin"],"server":["Netlify"],"status":["200"],"strict-transport-security":["max-age=31536000"],"vary":["Accept-Encoding"],"x-content-type-options":["nosniff"],"x-frame-options":["DENY"],"x-nf-request-id":["55af35c7-c2b4-4beb-9c91-a43f9c581c5b-33646414"],"x-xss-protection":["1; mode=block"]},"referrer":"","error":"net::OK"},"sample":0.1,"applicationSessionUuid":"8902c641-8a0c-4651-829a-ad510762c39a","flashingWorkflowUuid":"a162c2bf-1f32-4158-aaae-6418f03504b2"}) plus it says on the top "Flash Complete!" but under that it says "1 Failed target" and that says \\.\PhysicalDrive2: Checksum does not match for range [0, 227016703]: "4c94156c690ac74e"!="ea400e5387be89b" tried different computers still the same issue, tried running as an administrator still the same issue and I don’t know what to do anymore. Could anyone please help with this?
Hi @Janlxrd, thank you for reporting. Seems like we have other users experiencing this issue as well. It has been reported on the code repository as well: https://github.com/balena-io/etcher/issues/3197
My teammate maintaining Etcher noted that he’s working on fixing this issue. It takes a whole as it’s not a trivial change.
For now, judging from other users commenting on the issue, I believe you could use the flashed image fine. Can you try it please? Do you experience any issues?
